overbore of b18 throttle body
Old Nov 14, 2001 | 04:36 PM
JCushing's Avatar
Default overbore of b18 throttle body
i work on airplanes and theres a machine shop down the hall from me. i have a skunk2 itm wich is 64mm, i can have them bore it to 64 to match but its not the kinda thing they normally do (they dont normally do cars). what do i need for this? new throttle plate? basically i was just gonna have them bore it to 65mm tapered to 64mm. can i reuse the old plate and lower the idle to account for the extra air when the throttle is closed? id take it to a mechanic but basically this would only cost me a 12pack of busch and they have a full machine shop...
Old Nov 15, 2001 | 06:40 AM
Spade's Avatar
Default Re: overbore of b18 throttle body (JCushing)
go for it....but get a spare trottle body incase you cannot find a plate the right size.
Old Nov 15, 2001 | 06:43 AM
JCushing's Avatar
Default Re: overbore of b18 throttle body (Spade)
im thinkin i can make one outa sheet metal worst case scenario. just make a 64mm circle and tap it or just put nuts on the back to make sure it wont go anywhere. will this mess up my idle though, ive heard of people boring out their tb and having idle problems. its for a 98
Old Nov 15, 2001 | 06:59 AM
Spade's Avatar
yup, yer gonna have to adjust the idle and play with the part to get it working properly.
Old Nov 15, 2001 | 01:56 PM
JCushing's Avatar
is all i need a new throttle plate? i think the legend throttle plate is 64mm so i could use one of those or can i get away with sheetmetal. reason im concerned is im gonna be runnin boost soon so i dont want somethin flimsy.
Old Nov 15, 2001 | 02:11 PM
Spade's Avatar
I wouldn't use the sheet metal.....I would try something a little stronger....unless the sheet metal is a decent thickness.
Old Nov 15, 2001 | 11:15 PM
quick108's Avatar
I wouldn't recommend doing it yourself if you don't have much machining experience. Butterfly plates are not perfectly symmetric. At idle, the plate doesn't sit exactly perpendicular to the air flow. It is rather angled back for better throttle response, yet it keeps a tight seal. In order to machine this, the plate has to be slightly oval. For example (64mm x ~66mm). Raver Motorsports did a nice job on mine.
[Modified by quick108, 12:16 AM 11/16/2001]
EVS90
Mar 16, 2014 04:27 PM
bmxfelon420
Mar 20, 2010 04:11 PM
magicguy
Jan 30, 2009 02:00 PM
95_red_dc
Sep 11, 2006 09:47 PM
Initial DA6
Aug 29, 2002 03:24 PM
