Opinions on Hyperflex System Bushings?
Old Jun 21, 2002 | 08:54 AM
drumsy's Avatar
New User
Default Opinions on Hyperflex System Bushings?
I have a contact who can get me these for around $120.00. I have my front suspension almost taken apart for other work, and I noticed my lower control arm bushings had deep cracks. I figure a total kit right now will fix that, and also install the remaining pieces on my car. I realize this is a lot of labor. My questions is, is this a good name to go with, or is there a better set out there?
Old Jun 21, 2002 | 09:23 AM
Hondaaccordvtec's Avatar
Default Re: Opinions on Hyperflex System Bushings? (drumsy)
Hyperflex is made by Energy Suspension. I have that kit on my '94 Accord. You can also check out Prothane, thye make bushings as well. What kind of car?
If your thinking of installing these yourself - you WILL need a press for the LCA bushings or a torch to cut them out.
Old Jun 21, 2002 | 09:27 AM
drumsy's Avatar
New User
Default Re: Opinions on Hyperflex System Bushings? (Hondaaccordvtec)
1994 Acura Integra GSR. All of the bushings installs that I can't do will be done by a local shop.
Old Jun 24, 2002 | 07:38 AM
drumsy's Avatar
New User
Any other opinions?
Old Jun 24, 2002 | 08:51 AM
rolow's Avatar
If your stock's are worn the ES are worth the money.
Make sure you take sand paper to them. Just take the shine off with the sand paper. And make sure you use all of the grease that is supplied in the kit.
Old Jun 24, 2002 | 09:44 AM
drumsy's Avatar
New User
Default Re: Opinions on Hyperflex System Bushings? (rolow)
What is the sandpaper's purpose?
Old Jun 24, 2002 | 09:57 AM
rolow's Avatar
The poly bushings are self lubricating! You have to take the shine off so it will lubricate it's self. So they won't squeak! The shine is left from the manufacturing process.
emr88
Feb 20, 2011 05:29 PM
blulude92
May 22, 2006 10:58 PM
manyakiexpi
Mar 23, 2006 05:12 AM
matix
Nov 22, 2004 05:52 AM
spankey167
Oct 20, 2003 06:19 PM
