Omni coil over VS. Ground control
i have a 94 intgera ls.. and i already have a tokico blue shocks... not adjustable... i just want to know.. if omni springs.. will work good with these shocks... and how is it compare to a ground control... i have one cheap springs on my car right now.. and i hear the tire hitting the fender, is this because of the cheap springs from ebay... well i want to know... thank you..
i dont think the omni coil overs are just the adjustible sleeves like the GC are. i belive they are a full coil over suspension kit (adjustible springs and shocks)
ground control are just coil over sleeves you put on your existing shocks. i have GC sleeves and i like them.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">i dont think the omni coil overs are just the adjustible sleeves like the GC are. i belive they are a full coil over suspension kit (adjustible springs and shocks)
He sells both, a full coilover and a sleeved coilover. They're almost the exact same as the sk2 coilover.
</TD></TR></TABLE>He sells both, a full coilover and a sleeved coilover. They're almost the exact same as the sk2 coilover.
yes they do have coil over.. so i'm guessing omni is a pretty good springs... but the price is much lower than a gc... don't know why...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell »</TD></TR><TR><TD CLASS="quote">The omni coilover isn't dampening adjustable, just height and spring load.
Omni over ground controls anyday.</TD></TR></TABLE>
Steve (Omni) sells BOTH the full coilover suspension and the sleeve coilover, like Ground Control. OmniPower Website
I have the full coilovers and I must say they are astounding. I cannot say enough good things. But if I had to choose between Omni Sleeve coilovers and G.C., I'd chose G.C. anyday of the week. Not because Omni's are bad or anything, just for the simple fact that you can get custom spring rates on the G.C. You can't do that yet with Omni's. And like it was mentioned earlier, Omni = Skunk2 (more or less), so you're essentially getting their coilovers for a lil bit cheaper.
Which ever you get will be good upgrades but the G.C. will be better. Hope I helped.
i had the same problem deciding too, but i got GC's instead of omnipowers although i was really close to buying omnipowers but they were out of stock at the time
