OMG Stupid Wheel problem! HELP????
Old Dec 16, 2010 | 10:00 PM
Getownit's Avatar
Icon3 OMG Stupid Wheel problem! HELP????
Ok basically i have my buddies ae86 its 4 lug and one of the lugs was different from the other 3 on the back right wheel. so ive broke like 3 wheel keys on it and the last key broke off inside the hole of the wheel. and got stuck their so i cant get anything over the lug to pull it off and replace it as you can see here
ok heres a picture of a regular not messed up lug! see the space inbetween the lug and the inside of the wheel? i took it with my phone so srry if its not a great picture.
ok so after this we tried cutting out the top part but the problem was cutting into the wheel so eventually we messed around and chisled alot and beat the top of the lug off! as you can see here.
bent it grinded cut and still! the **** wont come out. all we can think of now is taking out the entire rear end and taking out the axle which will take alot of time. and it will make me have to buy new seals axle all kinda stuff and id have to cut the wheel stud off. anyone have any insite on how i can get this stupid *** lug off?!?! without doing all that work. and not cutting into the wheel i know its asking alot but just need some help
Old Dec 16, 2010 | 10:13 PM
mouab18c1's Avatar
Default Re: OMG Stupid Wheel problem! HELP????
Use a torch?
Old Dec 17, 2010 | 10:43 AM
Getownit's Avatar
yea could but dont wanna melt the wheel as well know what im sayin. i know ima have to mess up the wheel a little bit ub ti dont wanna completely screw it up.
Old Dec 17, 2010 | 06:31 PM
PyroProblem's Avatar
Ive had pretty good luck using an air hammer with a chisel bit removing lug nuts that owners have lost the key to.
Its tricky, but you can kinda work it in a counter-clockwise direction and hopefully it will undo itself...Good luck!
Old Dec 18, 2010 | 07:57 AM
Getownit's Avatar
hmm dont sound to bad! ty ima go try it out real fast
Getownit
Dec 18, 2010 08:01 AM
pinkspider
Mar 7, 2010 07:55 AM
iHATEspeedbumps.
Mar 31, 2005 08:20 AM
swt_666
Dec 14, 2004 08:03 AM
MidNiteMysT
Aug 25, 2003 04:04 AM
