oil temp/pressure questions
Old Mar 9, 2004 | 08:47 PM
Red_EM1's Avatar
Default oil temp/pressure questions
hey i was wondering if i could get some oil basics from you guys. i have a few questions:
What makes oil temp rise?
Is performance affected when it rises?
what is oil pressure?
what makes it rise/ drop?
what pressues are too high/ too low?
Old Mar 10, 2004 | 09:59 PM
Red_EM1's Avatar
Default Re: oil temp/pressure questions (Red_EM1)
anyone?
Old Mar 11, 2004 | 07:12 AM
JimBlake's Avatar
These are all kinda vague theoretical questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">What makes oil temp rise?</TD></TR></TABLE>Oil takes heat away from the combustion chambers, just like coolant does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Is performance affected when it rises?</TD></TR></TABLE>Viscosity drops when it gets hotter. Oil breaks down faster when it gets too hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">what is oil pressure? </TD></TR></TABLE>Same as water pressure, blood pressure, air pressure... How much pressure is behind the oil as it flows from the pump into the lubrication system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">what makes it rise/ drop?</TD></TR></TABLE>The pump makes the pressure, the pump's bypass/relief valve keeps it from going too high. Loose bearings make it go too low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">what pressues are too high/ too low?</TD></TR></TABLE>I don't know, but from a pure theoretical standpoint it's up to the engine designer.
crazyguy
Sep 27, 2007 04:38 PM
Shambo
36
Mar 21, 2005 02:37 PM
is3oo
Jun 6, 2004 06:49 AM
RGoose18
Nov 10, 2003 02:33 AM
Rhetoric
Aug 6, 2003 12:59 AM
