oil pump inside, will this casting slag cause troubles?
Old Oct 17, 2005 | 12:20 PM
B18EG6's Avatar
Default oil pump inside, will this casting slag cause troubles?
hey-
a while back I spun a rod bearing so I got a new oil pump. I replaced my rods but didnt do my mains, and I just got done doing my mains. Is it ok to reuse the oil pump? It had ~1000 miles on it.
Also - I noticed this when I was inspecting it:
There seems to be some slag or somethin left from the cast. Is it a wise idea to open the pump up, grind it down with a dremel and clean it out real good, then reassemble it?
Thanks!
edit - DOH forgot picture
Old Oct 19, 2005 | 05:11 PM
B18EG6's Avatar
Default Re: oil pump inside, will this casting slag cause troubles? (B18EG6)
bump - I dont like this, I wanna take it apart and fix it
Old Oct 26, 2005 | 10:23 AM
B18EG6's Avatar
i guess no one has encountered this?
Well.. ima take it apart then. anything I should look for to inspect on the pump?
expect a how to, i guess lol...
Mr. Future
Nov 22, 2015 07:46 PM
Lei Siew Long
Apr 17, 2002 08:54 PM
