oil pump failure
Old Apr 20, 2007 | 04:31 PM
conquer11s's Avatar
Default oil pump failure
recently my oil pump took a **** and shattered into a thousand pices. was wondering if any of you guys have taken the main bearings caps off of the crank with the mototr still in the car to see if any of the bearings have been swiped. wuld it be ok to do this? the motor is a ls/vtec turbo.
Old Apr 21, 2007 | 03:29 AM
civicstar's Avatar
Default Re: oil pump failure (conquer11s)
once torqued down and ran, you really cant loosen them, thats just asking to spin a bearing right there
Old Apr 21, 2007 | 04:13 AM
NJIN BUILDR's Avatar
It can be done.It's not really the best way but many people have done it that way successfully.
Old Apr 21, 2007 | 04:51 PM
conquer11s's Avatar
Default Re: oil pump failure (NJIN BUILDR)
what would be the right way to do this?
Old Apr 21, 2007 | 07:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conquer11s &raquo;</TD></TR><TR><TD CLASS="quote">what would be the right way to do this?</TD></TR></TABLE>
Take the engine out.Disassemble,inspect,clean and reassemble.
Old Apr 22, 2007 | 05:53 AM
mmuller's Avatar
Mad Scientist
you can check rod bearings with the engine in the car with ease.
as far as the mains; a little more tricky but still doable. the crank will drop down a little when main caps are off to be able to get to the top half of the bearing
supa ghetto star but yu can do it
93egallmotor
18
May 6, 2008 10:51 PM
Patman
14
Dec 24, 2006 07:30 PM
94-integra-ls
May 8, 2006 03:37 PM
Midwest Auto Salon
Jul 17, 2005 06:49 PM
boostedeghatch
Feb 28, 2005 09:54 PM
