Oil presure sensor
Old Dec 30, 2013 | 05:08 PM
D7FF M's Avatar
Default Oil presure sensor
Hi guys am I right in saying that the oil pressure lamp takes its feed from the vtec solenoid on the b18c engine? Thanks
Old Dec 30, 2013 | 05:22 PM
n/a2boost's Avatar
Default Re: Oil presure sensor
No it has it's own sensor on the back of the motor next to the oil filter.
Old Dec 30, 2013 | 05:23 PM
nub's Avatar
nub
Originally Posted by D7FF M
am I right
No
Old Dec 30, 2013 | 06:18 PM
D7FF M's Avatar
It's weird I have a wiring diagram of the car but nowhere mentions of an oil pressure sensor just the vtec one
Old Dec 30, 2013 | 06:28 PM
n/a2boost's Avatar
Old Dec 30, 2013 | 07:09 PM
nub's Avatar
nub
Depends on what you're using for referance. FSM shows the pressure switch to dash light in the electrical section for the dash or gauge diagram. The pressure switch itself is referanced several times in other section like the engine and fuel/emissions section.
Old Dec 31, 2013 | 12:52 AM
D7FF M's Avatar
You couldn't post the link could you? I'm new to the forum and still trying to find my way about
Old Dec 31, 2013 | 01:09 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
if you have to replace it remember it's i/8 bspt threads not 1/8 npt, if you want t o add a gauge etc, you need the adapter to convert to 1/8 npt
Old Dec 31, 2013 | 01:31 AM
D7FF M's Avatar
There's nothing wrong with the switch, I want to wire it up to the dash as the engine is not sitting In a Honda
Old Dec 31, 2013 | 05:10 AM
motoxxxman's Avatar
in that case, the lamp should have 1 wire going directly to a power source powered only when the ignition is on, and have the other lamp wire going directly to the oil pressure sensor. the sensor (switch) should ground to the block when pressure is lot, closing the circuit and illuminating the light, and will open the circuit shutting the light off when pressure is up.
Old Dec 31, 2013 | 06:32 AM
get an adapter anyway and get a switch that comes on at a higher pressure, those idiot lights are worthless, come on right before the engine starts tearing itself a new one, between 3-5 psi usually, a switch that comes on at 20 psi is a lot more useful, much more warning that something is up, best is a quality oil pressure gauge
DDream
Sep 20, 2012 05:57 AM
mgcivic359
Jul 11, 2007 02:12 PM
JDM_Acccord
Jul 5, 2007 09:29 AM
