oil pressure problem with my ZC
Old Oct 13, 2004 | 09:46 PM
MugenFlaredCRX's Avatar
Default oil pressure problem with my ZC
I'm having some problems with oil pressure with my zc powered crx. the car ran perfectly one day, then i took off the valve cover to get it powdercoated. got it back from powdercoating, got brand new gaskets all around, changed the oil. and now its running like ****. the oil idiot light on the dashboard flickers kinda fast about the same as the speed of the engine and also the engine ticks. i have no idea what could've caused this. i need some help.
Old Oct 13, 2004 | 10:05 PM
boostn420's Avatar
Default Re: oil pressure problem with my ZC (MugenFlaredCRX)
How good did you clean the valve cover before you put it back on. You know they sand blast the valve cover before they coat it and cleaning is up to you. Im sure there was a tag on it that said something to that effect when you got it back. Get and oil pressure gauge and see what it is.
del-sol-95
Jan 22, 2006 09:21 AM
MugenFlaredCRX
Oct 14, 2004 06:53 AM
