ECU Pins
Old Oct 12, 2004 | 05:38 PM
HeikDiesel's Avatar
Default ECU Pins
I need some pins to add wires to my ecu for my swap. Anyone know where I can but these? I want to make it as professional as possible
Old Oct 12, 2004 | 05:51 PM
drdisco69's Avatar
Default Re: ECU Pins (PhatAcuraIntegra)
What year car is this for? And I assume you mean the female pins from the plugs in the wire harness. I have a part number for what looks like female pins from an OBD 0 car from a terminal kit from honda, I don't know if it's for one or several. I'll check it thursday when I go in to work and let you know.
Old Oct 12, 2004 | 05:54 PM
eda6's Avatar
Find some plugs at the junkyard and remove the pins. That 's what i do.
How many do you need? I got a few laying around.
Old Oct 12, 2004 | 06:10 PM
drdisco69's Avatar
Default Re: ECU Pins (eda6 hatch)
I've just found those pins difficult to remove without damaging them, and with new ones you can run a single wire without a crimp or solder joint. Gives that professional look some people want.
Old Oct 12, 2004 | 08:18 PM
PrettyLude's Avatar
practice makes perfect
Old Oct 12, 2004 | 08:27 PM
b20izzle's Avatar
i was in the same situation as u...i went to the junkyard and found some pins. i cut the wires so that i would have enough to solder the vtec wire with the junkyard ones. its just a big hassle to try and crimp them, just solder them together.
I was wondering tho, i used obd1 pins and i have and obd2 car...will this work? either way its too late cuz i already soldered it haha
Old Oct 12, 2004 | 08:51 PM
HeikDiesel's Avatar
about a half dozen to be safe. If you wanna send them ill tip ya a litte
Old Oct 12, 2004 | 08:52 PM
HeikDiesel's Avatar
Default Re: ECU Pins (drdisco69)
Y es im talkin about the female pins that go into the wiring harness.
Old Oct 12, 2004 | 09:14 PM
Bailhatch's Avatar
Yup,get a plug from the yard. They come out very easily once you figure out the trick. Once you get it you can do several in a minute. A thin straight pick from a regular mechanics pick set is what I use. To figure it out I, cut half of the last row off my ecu plug to see where the little catch is.
Old Oct 12, 2004 | 09:24 PM
eda6's Avatar
Default Re: ECU Pins (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">the trick</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=587460
PhatAcuraIntegra pm me w/shipping info. I got some with 12" of wire
Old Oct 12, 2004 | 09:28 PM
Bailhatch's Avatar
nice, that pic is mint. Using a stiff pick will make it way easier than the paperclip. or find some stiff wire and sharpen it.
Old Oct 13, 2004 | 03:03 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">nice, that pic is mint. Using a stiff pick will make it way easier than the paperclip. or find some stiff wire and sharpen it.</TD></TR></TABLE>
Like tungsten rod or something like that?
Old Oct 13, 2004 | 03:05 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hatch &raquo;</TD></TR><TR><TD CLASS="quote">
PhatAcuraIntegra pm me w/shipping info. I got some with 12" of wire </TD></TR></TABLE>
How many is some? I said about a half a dozen earlier, im acutally gonna need about a dozen of em. Ill give ya 10 bux for em
Old Oct 13, 2004 | 04:16 PM
hondaguyef's Avatar
The obd0 and obd1 pins are different. I have both and also the "A" plug has different pins than the "B" and "C" plug. I have both kinds from both OBD0 and 1. All of mine have about 6" of wire or more on each as well. LMK. I can ship them asap.
Phil
Old Oct 13, 2004 | 04:32 PM
HeikDiesel's Avatar
Default Re: ECU Pins (hondaguyef)
Anyone have the pinouts for an engine bay on a 93 CX? I need those also. But ill get back to you on those pins, I think I might already have some
Old Oct 13, 2004 | 10:38 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
How many is some? I said about a half a dozen earlier, im acutally gonna need about a dozen of em. Ill give ya 10 bux for em</TD></TR></TABLE>
between 50-60. I found me a 92 acura vigor one day. I got obd 1 plugs too. Gray, orange, blue, green. My wire cutters were working exceptionally well that day.
CivicxTree754
Apr 27, 2011 11:51 AM
90Rexx
Mar 26, 2009 12:30 PM
894doorDX
Jan 18, 2008 12:39 PM
xXx Justin xXx
May 17, 2003 12:17 PM
zcivicz
Sep 10, 2002 06:08 AM
