Oil pressure bypass help asap
Old Feb 5, 2008 | 08:15 AM
wolfdawg's Avatar
Default Oil pressure bypass help asap
Is there any way to bypass the pressure sensor on my type-r? So I can run my usdm p73 ecu. I am geting a code p1259. Thanks Wolfy
Old Feb 5, 2008 | 09:36 AM
wolfdawg's Avatar
Default Re: Oil pressure bypass help asap (wolfdawg)
any one??? help me out.
Old Feb 5, 2008 | 06:03 PM
HondaPartsHero's Avatar
Technical Hero
From the ECU plug, cut the vtec pressure switch wire(D6) and tap it into the VTEC solenoid wire(A4). I do this for all the JDM swaps. No cel and vtec works.
Make sure you have sufficient oil though. The pressure switch is the sensor that decides if you have enough oil to cross over to vtec. This method bypasses it.
or you can buy one from me
94wip
12
Jun 20, 2024 07:23 PM
DoHc-
10
Nov 10, 2014 01:02 AM
DDream
Sep 20, 2012 05:57 AM
1sikhatch
Jun 5, 2009 07:35 PM
itz_nij
Aug 9, 2006 03:02 PM
