oil dripping from distributor cap..
I just replaced the head gasket on my 93 accord and i replaced the valve cover gasket, sparkplug tube seals , intake and exhaust manifold gasket and the o ring on the distributor and when the car is running milky oil is dripping from the distributor cap ... i replaced the oil after fixing the head gasket.. so it shouldnt be milky still .. is this just old oil and moisture thats making its way out or should i redo the o ring in distributor ?
93 accord f22a
93 accord f22a
if the oil on your oil cap isn't milky then it is probably just old oil. if it isn't leaking from the new o-ring that you put on the distributor then it could be leaking internally. only way to fix that would be to replace the distributor.
eckertd
Aug 29, 2015 04:43 AM
xcoregage
Dec 10, 2009 11:29 AM
