OEM LSD installation on J1 tranny
Old Feb 16, 2004 | 03:38 PM
teg92's Avatar
Default OEM LSD installation on J1 tranny
I check with this source (http://tech.hybridgarage.com/tech/lsd/) but it doesn't include clear info for older style J1 ball bearing type bearings. I am wondering if I need to worry about shimming the diff bearing when installing an OEM LSD (from a J1) in my non-LSD J1.
Thanks
Old Feb 16, 2004 | 07:26 PM
teg92's Avatar
Default Re: OEM LSD installation on J1 tranny (teg92)
bump
Old Feb 17, 2004 | 07:17 AM
teg92's Avatar
top
Old Feb 17, 2004 | 09:45 AM
PhatOptimo's Avatar
Yes, it will need to be reshimed unless the measurement form the edge of each outter bearing is the same on both differentials (highly unlikely though).
Basicly what he is doing here but measure from the end of each bearing.
*MIsta Bones Pic*
Modified by PhatOptimo at 12:58 PM 2/17/2004
Old Feb 18, 2004 | 04:46 PM
teg92's Avatar
Default Re: OEM LSD installation on J1 tranny (PhatOptimo)
Where do I get the specs for the clearance on a cable tranny casing? Is it still 0.0-0.1mm?
LocoJoe
Transmission & Drivetrain
Mar 2, 2011 06:55 PM
miyagi
Apr 20, 2006 11:55 AM
vha27
Dec 14, 2005 11:00 AM
JayDM_lsvtec
Dec 9, 2004 07:03 AM
