OEM ITR or OBX LSD?
Old Dec 28, 2006 | 04:08 AM
7rrivera7's Avatar
Default OEM ITR or OBX LSD?
If you had to choose, which would you use for a daily driver/weekend dragger?
Old Dec 28, 2006 | 12:12 PM
7rrivera7's Avatar
Default Re: OEM ITR or OBX LSD? (7rrivera7)
Anyone have an opinion?
Old Dec 28, 2006 | 12:29 PM
.dave's Avatar
i HAS questions ?
How much power are you planning on putting through it?
Old Dec 28, 2006 | 01:23 PM
7rrivera7's Avatar
Default Re: OEM ITR or OBX LSD? (daveG)
Not sure...Sleeved LSVTEC at 84mm, hi comp forged pistons, forged rods, Skunk PRO 1's, Alaniz head, ITBs, AnR compact header, 2.5" exhaust, Del SOl VTEC tranny with 4.7 final
Old Dec 28, 2006 | 03:51 PM
7rrivera7's Avatar
C'mon guys...I'm about to buy the ITR unles someone says no...
Old Dec 31, 2006 | 11:00 AM
soulpwr's Avatar
I'd rather have an itr since obx's are known to fail.
Old Dec 31, 2006 | 01:54 PM
blinx9900's Avatar
Default Re: OEM ITR or OBX LSD? (soulpwr)
itr ftw.
Old Dec 31, 2006 | 02:04 PM
7rrivera7's Avatar
Default Re: OEM ITR or OBX LSD? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">itr ftw.</TD></TR></TABLE>
What's 'ftw'?
Old Dec 31, 2006 | 05:56 PM
2slowGs-R's Avatar
"For The Win"
Old Dec 31, 2006 | 07:50 PM
Rigginit's Avatar
Default Re: (2slowGs-R)
Id go ITR. the ITR has LSD as well does it not? would be better gearing as a plus to the LSD
Old Jan 1, 2007 | 07:38 AM
b18sihatch's Avatar
EVERYTHING is known to fail, and if it doesnt fail its not a mechanical part, everything in the right sircumstance can fail.
with that being said, im going to run a obx lsd and i have had all bolts retorqed and had a reputable shop install it, i dont have any worries with it.
there are people who have had them fail and some that had NEVER had a problem with them
install is a major deal with the obx as the bolts should be retorqued and the lsd should have a good break in period to make sure everything is in and working right.
alot of people install it and beat the **** out of it and thats why they fail.
Old Jan 6, 2007 | 06:05 AM
turbocivic7901's Avatar
Be aware, even though the obx may not be up to par with the itr lsd it is a direct bolt on wheras in the ITR, depending on your application will not be a direct bolt on. That's what happened to me, I ended up selling it because I would have needed to convert my tranny to have an ITR final drive.
Old Jan 6, 2007 | 08:40 AM
non-VTEC's Avatar
Default Re: OEM ITR or OBX LSD? (turbocivic7901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic7901 &raquo;</TD></TR><TR><TD CLASS="quote">Be aware, even though the obx may not be up to par with the itr lsd it is a direct bolt on wheras in the ITR, depending on your application will not be a direct bolt on. That's what happened to me, I ended up selling it because I would have needed to convert my tranny to have an ITR final drive.</TD></TR></TABLE>
then you orderd the wrong one......OBX has a few diffrent part numbers and you needed the right one for your specific tranny.
to answer the guys original post. since you wont me making more than 350WHP or something close to that i would stick with thr ITR unit.
Old Jan 9, 2007 | 09:26 AM
Default Re: OEM ITR or OBX LSD? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
to answer the guys original post. since you wont me making more than 350WHP or something close to that i would stick with thr ITR unit.</TD></TR></TABLE>
I'm sorry I meant to say that the ITR doesn't line up properly (the transmission has to be modified) whereas the OBX can be ordered vehicle specific.
flatblack-h22
Mar 17, 2008 03:36 PM
DJ Gurgla GSR
Jul 15, 2006 09:36 PM
RaceMyGhost
Jun 27, 2006 11:29 AM
meanteg
Dec 9, 2001 02:41 PM
