OEM ECM options for better fuel delivery.
The car is a 94 GSR. I've removed the IAB valve body altogether. Consequently, as soon as V-tec engages, the engine is getting more air than it is programmed to provide fuel for, which, or course, puts me lean from 4400-5750rpm. I'm currently running rich as hell in every other RPM range to compensate for this & was wondering if there is a "quick-fix", if you will. I'm going to get a Hondata as soon as I can, but until then, is there an OEM ECM option for me? I'm not sure of V-tec crossover points in other V-tec engines, or their fuel maps, so any help would be appreciated.
I've tried asking questions similar to this and had little luck. The stock answer is the right one, get something to tune it properly, but you know that and are already going to do that. I wanted to clarify the IAB thing because I've seen people confuse it with the IAC and all kinds of things. Haven't read any of your previous posts so I didn't know who I was talkin to.
It's cool, I hear you. I've seen similar questions go unresolved also, so I didn't really think that I'd get a final answer, but you never know, so it doesn't hurt to try. At least I didn't get any serious, "Put the IAB back in.", replies! It boggles my mind that it seems like not very many people have tried this & stuck with it, so there really is a lack of good info. And what really sucks is that I KNOW there is a site that has all the different ECM's & their specs, but I have no idea where it is.
The ecu doesnt change the fuel for the air flow. If it changed, removeing the iab would trigger the engine light. If its too rich the problem is elsewhere.
I must have some REALLY bad timing...
all i can think of is using a B16A ECU with a more aggressive program, will this work? no need for IAB point, plus you could program the VTEC point too?
hth,
t..
Anyone know where the V-tec crossover is in an ITR?
best thing you can do is to have the P72 chipped, there are many programs for single butterfly intake:
J's racing is excllent offers ITR mapping for OBDI cars
as far as VTEC crossover in ITR it all varies on the TPS, but its roughly at 5.5k rpm
turboH22Aakkord
Oct 8, 2005 05:15 AM
