ODB1 Distributor for 1st Geb B16a
Old Feb 3, 2003 | 06:19 AM
7rrivera7's Avatar
Default Difference between ODB1 and ODB2 Distributor for 1st Geb B16a
Can someone tell me the part number for the ODB1 distributor needed to run a B16a? It starts with 'TD-' but there are a couple for this engine:
Civic:
TD-22U - 90-91 J-Spec
TD-73U - 99-00 Si
Del Sol:
TD-44U - 94-97 VTEC
I got this info from http://www.hondadistributors.net/distributors.php
Is there a difference between the ODB1 and ODB2 distributors? I know the difference between ODB0 and ODB1 is 16 vs 24 'teeth'.
I'm currently watching an auction on ebay but don't know if this is the correct one:
http://cgi.ebay.com/ebaymotors/ws/eB...401845401&rd=1
The seller says the distributor is A-Spec and he has a J-Spec engine. Should I NOT buy this one?
Thanks!
[Modified by 7rrivera7, 8:50 AM 2/4/2003]
Old Feb 4, 2003 | 02:57 AM
7rrivera7's Avatar
Default Re: ODB1 Distributor for 1st Geb B16a (7rrivera7)
Someone?
Old Feb 4, 2003 | 08:40 AM
Jeff C's Avatar
Default Re: Difference between ODB1 and ODB2 Distributor for 1st Geb B16a (7rrivera7)
Sorry, I dont know part numbers. You can use 92-95 GSR, 92-95 LS (with modification), or 94-95 Sol (DOHC VTEC). I am using a 95 LS dist on my 1g b16 head...I got it off Parts Trader for $135 shipped.
As far as I know, the obd1 and obd2 have the same internals. The only diff is the plug.
Old Feb 11, 2003 | 07:41 AM
Neukin's Avatar
Default Re: Difference between ODB1 and ODB2 Distributor for 1st Geb B16a (Jeff C)
the part number on mine is td-22u
Old Feb 11, 2003 | 01:43 PM
Wes d's Avatar
Default Re: Difference between ODB1 and ODB2 Distributor for 1st Geb B16a (toyosupr)
mine is td 81u It was suposedly from a 99-00 si
I repined it for my obd1 crx and it works great.
[Modified by Wes d, 10:45 PM 2/11/2003]
Old Feb 11, 2003 | 02:57 PM
CHEETAH's Avatar
they will work, but not effectively, car will be sluggish and wont make the power it should ... because the pickup teeth is different between the two distributors.
Greg
TheHatchHog
11
May 11, 2003 01:20 PM
slowpokesi
21
May 29, 2002 08:05 PM
VTECVillain
Dec 21, 2001 09:23 AM
