OBDI vs. OBDII injectors
I searched but couldn't really find the info i was looking for.
Just wondering if any of your are running OBDII injectors in your OBDI car? I read that all you have to modify are the plugs and you're good to go. Any other difference i should know about, or am i better off with just OBDI injectors? Thanks.
all you have to do is modify the plugs. I would use whatever injector your wiring is made for. it simple that way. If you want aftermarekt then all of them are obd 1 style clips and you have to splice and dice
Yup, they're both high impedance... When using stock injectors I typically use OBDII ones just because they look cleaner and easier to release connector clip...
I don't know for sure but I should have made this clearer before... You're not using OBDI H22 injectors (345cc) are you? If so then what I said before was wrong, they would be low impedance... I didn't even think about that till im_poor asked if you had the resistor box... If you're workinw with B/D series injectors then you're fine (all HI)...
Ok, here's the thing, i have a 92 LS (which is OBDI) with stock injectors with no resistor box. I plan to replace them with low mileage OBDII ITR injectors. Will it work? Or should i just send my current injectors to RC to get them serviced?
Thanks again guys.
Thanks again guys.
