OBD2b to OBD1
I searched but because I don't know a lot about this topic I'm not sure what I'm looking for. I need to eliminate the o2 sensor on the cat. I have a 00' civic, d16y8 with stock P2P ecu. I know it's going to throw a code with the cat o2 sensor gone. I can I get a P28 ecu with a obd1 conversion harness and still have the car run up to par? Or will the conversion harness work with my P2P ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi »</TD></TR><TR><TD CLASS="quote">I searched but because I don't know a lot about this topic I'm not sure what I'm looking for. I need to eliminate the o2 sensor on the cat. I have a 00' civic, d16y8 with stock P2P ecu. I know it's going to throw a code with the cat o2 sensor gone. I can I get a P28 ecu with a obd1 conversion harness and still have the car run up to par? Or will the conversion harness work with my P2P ecu?</TD></TR></TABLE>
obd1 p28 will work just fine if you get a jumper harness to convert. i suggest boomslang fabrication.
you can run the obd2 ecu and a test pipe with the secondary 02 in place if you do the o2 spark plugs non-fouler trick http://forums.evolutionm.net/s...15795
Well that's my problem. The high flow cat I bought o2 holes do not line up correctly and I cannot use the o2 because it's too long. So the non fouler trick would make my problem worse. So rather than going through the hassle of getting a new cat I thought I would just eliminate the o2 sensor all together. Eventually I want to run hondata so I would be changing my ecu in the future anyway.
civicshowracing65
Mar 9, 2004 11:33 AM
MeanGreenEG9
Dec 4, 2002 05:20 PM
