OBD2 DTC code help
Old Jan 21, 2004 | 04:36 PM
civic-4-ges's Avatar
Default OBD2 DTC code help
My mil cam on the past couple of days and I finally got a chance to check out what code came up. The mil shut off right before I was able to retrieve them, but I was able to retrieve a code. I got a P3362, which I cannot find anywhere online from my usual code sources.
Anyone know what thisd may be pointing to?
Old Jan 21, 2004 | 07:10 PM
W C L's Avatar
Default Re: OBD2 DTC code help (civic-4-ges)
alot easier if ya had a jumper wire to read the code through your flasjin check engine light....
i have a genisys diagnosis machine it kidna sucks when it throws codes to me like that and i dont have manual that helps u out with the coding on that...... i knwo they dont read the vtec system its comes out with that kidna format
Old Jan 24, 2004 | 05:38 AM
Default Re: OBD2 DTC code help (W C L)
Anyone else?
Old Jan 24, 2004 | 08:28 AM
hondatim's Avatar
The code does not exist. Try resetting ECU and drive again. If light comes back on, then check code. If same code, may have communications error with scan tool.
BTW, W C L, how do you personally like the Genysis scan tool. We have one that we use in our shop, and personally I like it. However, I really liked the Vetronix Mastertech for Honda and Toyota better(what we used in the dealerships)
ddevault1
Honda CR-V & Element
May 31, 2015 02:26 PM
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
97teg415
Jun 1, 2008 07:03 PM
CBR600OnTop
Jul 3, 2003 01:14 PM
cp_harrington
10
Jan 25, 2003 06:43 PM
