obd2 d16 into 93 civic........problem with Iac sensor...how do i wire it
Old Jul 3, 2004 | 10:10 PM
ensracer's Avatar
Default obd2 d16 into 93 civic........problem with Iac sensor...how do i wire it
we put this obd2 motor into a 93 civic the only thing that we changed was the distributor and the car runs fine its just that the rpms go up and down and the acr shuts of once ina while because of it..... the only sensor that we could not fugure out is the iac because the motor has a 3 plug and the harness a 2 plug....so how can i make this work?
Old Jul 5, 2004 | 06:39 PM
ensracer's Avatar
ttt
Old Jul 5, 2004 | 10:30 PM
PHiZ's Avatar
Default Re: (eduardo)
http://www.ff-squad.com/tech/w...8.jpg
-PHiZ
Old Jul 7, 2004 | 08:56 AM
ensracer's Avatar
Default Re: (PHiZ)
awsome................thanks man
Old Jul 7, 2004 | 09:04 AM
EE_Chris's Avatar
Default Re: obd2 d16 into 93 civic........problem with Iac sensor...how do i wire it (eduardo)
If you're using an ECU meant to control a 2-wire IACV - your fucked.
All the re-wiring in the world isn't gonna help you out here.
ECUs meant to control a 2-wire IACV will NEVER control a 3-wire IACV and vice-versa.
Old Jul 7, 2004 | 11:08 AM
ensracer's Avatar
damn!!!!!!!!!!!!!!!!!
Old Aug 15, 2013 | 05:57 PM
danielolaguez92's Avatar
So what ecu is recommended for this motor and car?
Old Aug 16, 2013 | 03:31 AM
Blown90hatcH's Avatar
What motor and car? Specifics....and 9 year old thread.
Old Aug 16, 2013 | 07:53 AM
HondaPartsHero's Avatar
Technical Hero
Use the p06 and any d series manifold with the exception of the y7 or Auto Y8
NCDS
Oct 29, 2011 01:47 PM
93eggo
Jul 9, 2011 06:16 PM
mikej94civex
10
Feb 12, 2010 03:54 PM
low97accord
Oct 19, 2006 12:06 AM
