obd1 code 14 on obd 2 engine
Old Aug 25, 2005 | 07:13 AM
jozzy's Avatar
Default obd1 code 14 on obd 2 engine
i using a p28 on a obdII 96 civic using a conversion harness
it uses the single wire oxygen sensor so we got a code 41 primary heater circuit so we disable that and re-burned the chip, then we got a code 22 VTEC Oil Pressure Switch defective circuit or unplugged, obd2 dont have vtec oil pressure switch so we disable that also
now i getting a code 14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
Any idea on what is causing this problem, or how to fix it
we are using uberdata
thanks any ideas are welcome
jdmd15crx
Aug 18, 2016 06:45 PM
Shift_Fast
Mar 11, 2005 06:35 PM
lsvtec42
Mar 8, 2002 04:01 PM
