obd0 to obd1 wiring problems please help!!!!
Old Feb 24, 2004 | 07:07 PM
Cornwhiskey's Avatar
Default obd0 to obd1 wiring problems please help!!!!
IM doing a lsvtec in my 88 crx and im going to buy the wiring harness two switch it over inside the car and i was told there are 4 or something extra wires where do they go and what do i have to change on the motor wiring...please help
Old Feb 25, 2004 | 02:39 PM
Fobtions's Avatar
Default Re: obd0 to obd1 wiring problems please help!!!! (onefastcrx88)
u need to wire in a 4 wire o2 sensor. and all the vtec stuff if its not already done. also need a way to check CELs
Old Feb 26, 2004 | 03:10 PM
Default Re: obd0 to obd1 wiring problems please help!!!! (Fobtions)
thanks alot for the help
Old Feb 26, 2004 | 06:32 PM
Kataku2K3's Avatar
Really on all the nonOBD-OBD1 swaps I've done for Rex's, etc. I've always made my own jumper which was pretty much plug and play with the interior wiring harness (I only say pretty much because the interior will have been modified for VTEC, VTM, and the 4 wire oxygen sensor)... Scanning the ECU for a code isn't that big of a deal... Simply ground D4 and it's just like shorting the SCS connector on an OBDI/II chassis... How you wire it really depends on the jumper, with the jumpers I've made nothing has to be hardwired (seems better to me that way) but if yours does require it then I'm sure you'll be running lines out for the oxygen sensor, VTEC, VTEC press, and anything else that I may be forgetting...
This is Mike's (jdmDXrex) jumper that I made for him awhile back... Nothing special but as you can see it's plug and play once you're interior/engine wiring harnesses have been wired for VTS, VTM, OBDI/II dizzy, high impedance injectors (only if you want to take out the resistor box), and the 4 wire oxygen sensor...
Old Feb 26, 2004 | 10:20 PM
mmuller's Avatar
Mad Scientist
Default Re: obd0 to obd1 wiring problems please help!!!! (Kataku2K3)
just to add:
vss and obd1 dizzy
MadCrx
Apr 21, 2018 10:31 AM
rossi1
Oct 16, 2011 09:56 AM
superfast666
Mar 22, 2008 07:29 AM
junior40er
May 10, 2006 11:07 AM
