o2 sensor
Old Dec 1, 2005 | 03:32 PM
dragaholic's Avatar
Default o2 sensor
does an o2 sensor go bad if it is left on the manifold that is not in use.
Old Dec 3, 2005 | 11:21 AM
vtewcjunkie81's Avatar
it can if it's left outside where moisture can get to it
Old Dec 3, 2005 | 02:00 PM
BigMoose's Avatar
Default Re: o2 sensor (dragaholic)
Typically no. If moisture condenses on/within it... like rain, and then freezes, the ceramic thimble can shatter.
Old Dec 8, 2005 | 07:56 PM
duke66's Avatar
Default Re: o2 sensor (BigMoose)
I have been reading your old posts about O2 sensors and wondered what happened to the unit you and your partner were working on?
I have just assembled a rev 5 DIY_WB board before I had a sensor but just found one tonight. You presented a wealth of knowledge and I enjoyed reading it all.
Since finding the threads about AFR I have learned alot that I wish I knew back when I was Dragracing seriously, course this stuff was just a dream then.
I am doing this to help tune my Son's 68 Camaro,we've had it since '85.
I have also read a ton about reading plugs and found out everything I didn't know back when no one would tell you how to do it in the old days. An AFR would sure go a long way to fill in the gaps.
Do you know what signal a person would be able to use for data logging RPM? I think between RPM and AFR you could really dial in a carb now that I have learned there are about 6 or 7 different things to tune on a Holley carb.
Boy were we dumb in the old days.
Thanks for any help, it's all very interesting,
Terry
Mfkafka
Honda CR-V & Element
Mar 12, 2013 12:19 PM
phoshyzzle
Oct 18, 2009 07:52 PM
