O2 and knock sensor woes. I need some advice.
Old Sep 11, 2002 | 05:18 PM
T_Rex's Avatar
Default O2 and knock sensor woes. I need some advice.
I have a '90 CRX with a first gen JDM B16A and the PW0 ecu. I just finished installing a DC 4-2-1 header and ran into a problem with the O2 sensors-
The stock manifold had two O2 sensors on it, but the DC only has a spot for one. For now, I just left one off and taped up the other wire, but I wasn't sure what to do, so I asked the question in the CRX forum and got these responses.
https://honda-tech.com/zerothread?&i...657235#2657235
Coincidentally, the ecu is flashing a code 23, which means the knock sensor is bad too. Now I'm wondering if I should go to all the trouble/expense of having the two bungs welded into the header for the O2 sensors AND buying a new knock sensor?
Maybe I should just get the ecu chipped with a program that disables these sensors?
What do you guys think? Many thanks.
RanCRX
Nov 30, 2009 04:08 PM
steronz
Nov 2, 2003 08:39 AM
T_Rex
Sep 13, 2002 11:37 AM
FastFoot
Apr 30, 2002 06:09 AM
1.8EG-T
Nov 5, 2001 12:08 PM
