O2/Cat problem... need some advice please!!
Hey,
I'm new to Hondas, so there might some common issue here that I'm not aware of... either way, what's your take on this?
I bought an '01 Si recently (2 weeks). The PO told me that the car was throwing a CEL because of a bad O2 sensor. He had one replaced (apparently the wrong one), so the light stayed. He then had the other one changed right before I got the car.... so I'm basically sitting with 2 new O2 sensors.
The car is still throwing the CEL intermittently, so I took it to my mechanic for a look and a basic checkup on the car. He tells me that the light is coming on because of a variance in readings between the two sensors, which would indicate a bad cat.
Is this a common issue? I'm a little bothered by it... a new OEM cat is in the 1200 (canadian) range, and an aftermarket one won't last all that long. I only got the car for 5400, so I'm not happy about having to spend another chunk just to fix it. I was told that it won't be necessary... the car did pass the e-test, so it can't be all bad. I can live with the cat. But if something else goes that would cause a CEL, I won't know...
I want to know how much of an issue I actually have on my hands here...
Advice?
Advice?
there is alot of things that can throw o2 codes....from bad connections, to the guy running race/leaded fuel in it, to a bad cat (which can be caused by leaded fuel), to the car running rich. without being able to scan and look at it myself I would just be guessing. I have also seen BNIB bad o2 sensors, sometimes those things get kicked around at the parts stores. why cant you use an aftermarket cat. ? it'll last you several years as long as you dont put leaded fuel in it.
he prolly wants to sell you the oem cat so he can jack up the price and make more money. i got my magnaflow cat for 125 online and put it in myself in about an hour total
Good to know, I might have to look at that route. How difficult is it to install a cat? I'm no mechanic, but I'm no idiot either... any special tools required?
I've also got a handful of mechanically inclined friends... might have to go pick up a 24 and get someone over for a little tooling fun. If only it wasn't freezing outside...
b 1 6 e g
Feb 27, 2006 11:29 AM
