notching syncros????
Old Aug 23, 2005 | 04:20 PM
Timmay's Avatar
Default notching syncros????
Anyone heard of this or tried it?
ive heard that if you notch out every other tooth on the syncro it will help with power/full throttle shifts.
thinking about trying it out for ***** and giggles but was checking to see if anyone has tried this??
Old Aug 23, 2005 | 09:09 PM
Timmay's Avatar
Default Re: notching syncros???? (Timmay)
hmm do i have to be the test rabbit?
Old Aug 24, 2005 | 12:07 AM
sporkcrx's Avatar
Sounds like BS to me
Old Aug 24, 2005 | 05:34 PM
Timmay's Avatar
Default Re: notching syncros???? (sporkcrx)
the all mighty mista bone says "no go"
Old Aug 24, 2005 | 07:14 PM
SOHCmaster's Avatar
The V8 guys do this to alot of 4speed clutch cars to rid the syncro grind.
Old Aug 26, 2005 | 11:03 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
try it and let us know. i am doubtful.
Old Aug 26, 2005 | 04:28 PM
FalkenSiR's Avatar
Default Re: notching syncros???? (not so civic)
Try it and make sure you have an extra set. Just in case.
Old Aug 26, 2005 | 04:29 PM
Timmay's Avatar
Default Re: notching syncros???? (fast88std)
na ive been told not to do it by a good source
Old Aug 26, 2005 | 05:46 PM
SOHCmaster's Avatar
yeah I think our honda syncros need drag to slow em up and not slippery ones like v8 trannys and cause more problems. Ill look into it more in depth.
Old Aug 26, 2005 | 06:32 PM
slomofo's Avatar
GDD Member
Is this supposed to be some type ghetto fabbed dogbox?
Old Aug 27, 2005 | 06:00 AM
machine4321's Avatar
yes its a makeshift dogbox
my buddy di this to his 600hp taln ..but there is no point in doing thr syncro its slef as the teeth on the syncro dont relly do a lot of the grabing ..there just there to guide the sleeve over the hub.
to do this properly you would have to grind down every other tooth on the hub AND syncro as well as the hub to ...it just makes the next gear grab much easier ..there is no room for error though and expect a grin every shift ...and no more baby shifting ...
every shift must be fast for things to mesh up
Old Aug 28, 2005 | 08:03 AM
Mista Bone's Avatar
D Tranny Guru
While this works for old V8 trannys like Muncie and Top Loaders, they use full floating synchros, aka the are free to spin.
Honda doesn't, the synchro only move approx. 1/2 tooth either way, that all.
You could TRY removing every other engagement tooth off the gear itself, but why?
Scuff the gear face where the synchro "grabs" the gear, like GearSpeed shows to do. At first the tranny will be a little notchy, but in 300 miles it will be like butter!!!!!
1-2-3-4 powershifts, not even a hint of grindage.
Sadly, my tranny I did that too, only lasted 3 days. The Kaaz LSD either spit out a axle or exploded.
Old Aug 28, 2005 | 09:06 AM
Default Re: (Mista Bone)
[QUOTE=Mista Bone]
QUOTE]
so you scuff the cone on the gear. does this work with the factory brass rings too? or are you using the carbon coated ones? i completely understand the reason with the carbon ones.
Old Aug 28, 2005 | 09:52 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (not so civic)
I did it using the stock synchros. I had to replace 2-3-4 due to 5 years of HARD driving, so while I was in there, tried what GearSpeed had suggested. On one cone the was brass build-up, but it comes right off with a 120 grit flapper wheel.........
takes about 90 seconds per cone, I don't bother with 5th. Tearing apart and putting the shafts back together is the hardest part.
ZoomerDude
Honda Ruckus and Scooters
Dec 3, 2024 07:20 PM
RR98ITR
27
Mar 1, 2006 07:47 PM
sircrxracer
Jul 26, 2004 12:36 PM
gutted
Acura TL, RL & ZDX
Nov 18, 2003 09:36 AM
civic_sir94
22
Oct 12, 2001 03:53 PM
