Not sure what is causing this CEL
Old Jan 7, 2003 | 08:48 PM
blufke's Avatar
Default Not sure what is causing this CEL
I still occasionally get a CEL code for the o2, so CEL 1. it is sometimes accomponied(spelling?) by my cd changer no longer working, which is remedied by resetting the ecu. i dont get any studdering or anything(except maybe a little rougher at idle, but could be my imagination), just the o2 CEL and the occasional having to listen to the radio. what could it be? a common ground between the two not making its contact, or something else, i dunno. help me out please. thanks.
Old Jan 8, 2003 | 07:45 AM
badCRX's Avatar
New User
Default Re: Not sure what is causing this CEL (blufke)
what car and year is this?
Old Jan 8, 2003 | 09:25 AM
blufke's Avatar
Default Re: Not sure what is causing this CEL (badCRX)
92 vx w/b18b
[Modified by blufke, 6:26 PM 1/8/2003]
Old Jan 8, 2003 | 01:26 PM
badCRX's Avatar
New User
I am surprised you get a code 1. Are you certain its not a code 10? I can never say I had a code 1 for a 92+ Civic. It's usually just a code 41 on 92+ Civics if there is something wrong with the O2 sensor. You have a VX so you how did you wire up the 4 wire O2? Did you get an Si wire harness?
Old Jan 8, 2003 | 04:50 PM
blufke's Avatar
i am using a 4 wire and it plugs up to the engine harness. there shouldnt be anything i need to wire(right?) for it to function properly.
now after resetting the ecu after spraying carb cleaner in the intake mani and trying to make my cd changer work again, the changer isnt even coming on. i dunno what the problem is. crap.
Old Jan 9, 2003 | 12:15 AM
Cnote's Avatar
did you use your stock VX harness and was your motor one of the few that came with a 5 wire O2? This could be your problem
Kaaruchi
Jun 4, 2012 08:02 AM
LS AzZkIkr
Apr 9, 2007 08:01 AM
93FastLs
May 20, 2005 05:39 AM
suckawillis
Dec 18, 2004 08:07 AM
Combustion Contraption
Jun 13, 2004 10:20 PM
