NOS Question
Old Mar 3, 2004 | 01:40 PM
crxsirvtec's Avatar
Default NOS Question
hey..
i would like to run a 40 to 50 DRY shot on my B16A1..
I have the CR up to 10.7:1
Stage 2 Cams.
Skunk2 Intake...
I want to know the ups and downs running this..
thanks
Old Mar 3, 2004 | 01:56 PM
torr's Avatar
Default Re: NOS Question (crxsirvtec)
good-
instant horsepower from a flick of a switch
can't beat dollar to horspower ratio
adjustable from 40 to a 75 shot
easy install
whip its
bad-
constant no2 refills=$
incorrect install= breaking something
Old Mar 3, 2004 | 02:17 PM
crxsirvtec's Avatar
how long does a 10 lb bottle last?
Old Mar 3, 2004 | 02:53 PM
torr's Avatar
depends on how much you use it.
my first full bottle lasted me 2 days due to the fact that i had an itchy trigger finger. when i first installed my kit, i sprayed so many times just to show off and have fun. sometimes a full bottle would last me a week. after a while i got more conservative, and only sprayed when i would race someone, which was everyother weekend. bottle refills can get anoying sometimes, at 50 bux a pop.
if i had to guess i would say that a full bottle would last up to 15 runs through 4th gear at full throttle.
Old Mar 3, 2004 | 04:46 PM
crxsirvtec's Avatar
Default Re: NOS Question (torr)
thanks
Old Mar 3, 2004 | 08:08 PM
N2O's Avatar
N2O
Refills run about $3 a pound you do the math. Zex makes a great kit for first time nitrous users. Make sure you pull some timing out and have enough fuel and you will have no problems. My last motor in my street car had I would guess about 100k miles on it and well over 100 bottles of nitrous sprayed through it. I even sprayed it at 100hp for a couple of bottles. Zex says you get about 3 minutes at the lowest hp setting. The time a bottle lasts depends on a lot of different things including weather and temperature. Have fun good luck
Old Mar 4, 2004 | 07:00 AM
specv5150's Avatar
Default Re: NOS Question (N2O)
Semi off topic...
how hard would it be for someone to install a N2O kit themself.
Old Mar 4, 2004 | 07:57 AM
boosted-delslow's Avatar
Default Re: NOS Question (specv5150)
I put the Zex kit on my car in about 1 hour!!! It is pretty easy!!!
Old Mar 4, 2004 | 08:00 AM
specv5150's Avatar
Default Re: NOS Question (boosted-delslow)
I am goign to read up on some install faqs, information. I have been thinking about my goals and N2O just seems like the cheaper way to go.....
Old Mar 4, 2004 | 08:06 AM
JDMorgan's Avatar
zex is the only dry kit i would buy. i only heard good things about them. an hour is quick think about this and figure it out urself. install bottle mounts in trunk, put bottle in, drill hole for blowdown tube, screw blow down tube on, run line for nitrous, mount nmu, hookup lines, put switch in car, run wire to nmu, run rest of the wires like tps and whatnot. clean up ur install and add the tephlon tape to the n2o fittings.
Old Mar 4, 2004 | 02:09 PM
red91sit's Avatar
Default Re: (KraZEtEggIE)
Teflon tape? My NOS kit said to not use this because it can jam the solenoids open.
Old Mar 4, 2004 | 02:42 PM
torr's Avatar
Default Re: (red91sit)
all kits are pretty easy to install, but the zex is alot simpler due to fact that it has a box that all the hoses goes into. the hardest part about an install is where to mount everything. after you've mounted everything all the hose and wire hookups are easy.
i used teflon tape on my hookups, the only part that i didn't use teflon tape on was where the main nos line hooks up to the bottle. when using teflon tape, only wrap the threads and not the ends, that way no tape debris goes anywhere.
Old Mar 4, 2004 | 03:56 PM
dd_biggy's Avatar
Default Re: (torr)
so spraying the 55-75 shot would be safe on his stock engine then? also, what about fuel management? should he worry about changing the stock injectors/fuel pump? Makes a diff. if you have an auto for how large a shot you want to use too, they aren't especially fun/cheap to replace.
Old Mar 4, 2004 | 05:55 PM
torr's Avatar
Default Re: (dd_biggy)
stock honda blocks can handle up to a 75 shot. no pump or injectors are required for this shot. just get colder plugs, gap them about .36. retaed timing about 3 degrees.
Old Mar 4, 2004 | 09:03 PM
RTE117's Avatar
Might wanna make sure the overlap from Stage II's isn't gonna render the nitrous next to nothing.
Old Mar 4, 2004 | 10:03 PM
JDMorgan's Avatar
hmmm, i know a couple people who used tephlon when they did their install. i should tell them....whatd u use so there are no leaks? just listen?
Old Mar 5, 2004 | 07:43 AM
smokinem's Avatar
you might wanna get a different fuel regulator if your gonna run nitrous
Old Mar 5, 2004 | 12:51 PM
red91sit's Avatar
Default Re: (smokinem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokinem &raquo;</TD></TR><TR><TD CLASS="quote">you might wanna get a different fuel regulator if your gonna run nitrous
What kind? Would any aftermarket adjustable one work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">
Haven't filled the bottle yet i think i will do what torr said also with the teflon tape.
Also it wouldn't be too hard on an auto as long as you don't spray in the low gears right? I mean like 100-125 shot?
Old Mar 6, 2004 | 12:02 PM
crxsirvtec's Avatar
how does the nitrous work with stage 2 vtec cams??
Old Mar 6, 2004 | 05:24 PM
crxsirvtec's Avatar
Old Mar 6, 2004 | 07:45 PM
red91sit's Avatar
Default Re: (crxsirvtec)
What do you mean? It will work just fine unless you have so much overlap the nitrous blows right through the combustion chamber.
Old Mar 7, 2004 | 05:52 AM
crxsirvtec's Avatar
what is too much overlap??
Old Mar 7, 2004 | 07:52 AM
SUB-0 H23's Avatar
teflon paste is recommended not teflon tape. 27.50 for 10lb refills.
Old Mar 7, 2004 | 09:19 AM
red91sit's Avatar
Too much overlap would be when the intake and exhaust are both open for too long. Some N/A race cams have this problem. I'd think if you had a ton of overlap some of the fuel and air/nos could exit it in unequal amounts causing it to have messed up a/f ratio a little but it shouldn't hurt the only thing it would do would be make the shot a little smaller.
Old Mar 7, 2004 | 02:06 PM
crxsirvtec's Avatar
how many degrees should i worry about??
that's what i was asking..
at what point is too much overlap..
