Non Rice Down Force
Old Feb 3, 2003 | 01:33 AM
  #26
XxDemonxX's Avatar
Default Re: Non Rice Down Force (texan)
if you dont wanna look ricer......put some weights in ur trunk lol...are you talking about all the time or just when you race or whatever???
Old Feb 3, 2003 | 06:11 AM
  #27
crxste's Avatar
Default Re: Non Rice Down Force (XxDemonxX)
So these things actually work?
cos I'm having ago at a top speed event this summer so as much downforce to keep the car stable at speeds approaching 150mph will be nice
Old Feb 3, 2003 | 06:24 AM
  #28
Raz1983's Avatar
Default Re: Non Rice Down Force (crxste)
i have no experience with it, but its supposed to work really well.
that and a thingy (i dunno what to call it LOL like a / on top of the rear spoiler) would be enough im guessing.
Old Feb 3, 2003 | 06:54 AM
  #29
evolve's Avatar
Not really, that's just to relieve the high pressure building up behind the bumper (in an effort to reduce aero drag). I'll actually have to disagree with Kamin on his definition of a diffuser, as an air damn and an airfoil diffuser are two very different things IMHO. An air dam is just as he described it, a "dam" that attempts to prevent airflow from reaching certain points. These are often used in conjunction with front splitters to direct air up and over, or around the sides of the car rather than under it (which is usually a very aerodynamically dirty area). A diffuser on the other hand is an airfoil (any device designed specicially to alter airflow) who's primary purpose is to help evacuate air from under the car in a controlled manner by creating an area of strong low pressure to the aft of the vehicle. So an air dam attempts to prevent air getting underneath the car, and a diffuser attempts to evacuate what air does get under effectively (while also influencing the Center of Pressure, the aerodynamic equivalent of Center of Gravity). A picture of the *** end of a diffuser section (notice the smoothly upward arcing aluminum airfoils)...
Very good post.
Someone does understand. Your completely correct in saying an air dam is not a diffuser. A diffuser is designed to divert flow, while a conventional air dam is simply designed to prevent some flow under the vehicle. A conventional front air dam increases frontal area, with inturn causes more stagnation.
Are you truly Texan, or are you called Texan?
Old Feb 3, 2003 | 09:43 AM
  #30
texan's Avatar
Default Re: Non Rice Down Force (evolve)
I'm from Texas, living in California now.
93fd4life
Honda Civic (2006 - 2015)
Nov 5, 2012 07:03 PM
DelSolMarine
Mar 16, 2006 05:23 PM
sol_1320
30
Dec 29, 2003 01:48 PM
