no spark from my b16???
Old Mar 20, 2002 | 12:01 AM
prjctCIVIC's Avatar
Default no spark from my b16???
for some reason my jdm b16 is not producing any spark?? what could be the cause of this??? it s 90 civic si w/ a jdm b16, thanks
Old Mar 20, 2002 | 12:07 AM
julow's Avatar
Default Re: no spark from my b16??? (prjctCIVIC)
check your distributor. if that is good make sure you are getting a spark from the coil. put the coil wire really close to metal, turn the lights down, and try to start the car.
Old Mar 20, 2002 | 05:15 PM
gokooljapan's Avatar
did you just drop in a motor? or did it just stop on you? give us somemore details, thanks
Old Mar 22, 2002 | 12:01 AM
prjctCIVIC's Avatar
Default Re: no spark from my b16??? (gokooljapan)
just dropped the motor and it was driving fine for about 30-45 minutes..then the tach started getting all wild so i shut the car off and ever since then it wont start back up.....any help is appreciated, thanks
Old Mar 22, 2002 | 06:38 AM
rainforest's Avatar
new cap and rotor. ground the spark pug wires and check it out.
Old Mar 22, 2002 | 07:51 AM
sounds like a distributor problem.....
1. check all your sprak plug wires and make sure they are properly inserted and snug
2. if you have an extra distributor, try that
3. cap and rotor
if your car turns and doesnt fire up:
check your ignitor
nonvtec92
Aug 26, 2010 01:46 PM
halocore
Jan 8, 2010 04:20 PM
streetcartuner
Jun 5, 2007 10:03 AM
brent_G
Jul 3, 2002 01:45 AM
prjctCIVIC
Mar 20, 2002 10:56 AM
