No cel and no vtec on a minime?!?!?!
Old Jun 6, 2005 | 03:24 PM
WildPig's Avatar
Default No cel and no vtec on a minime?!?!?!
Everthing is hooked up right and it still doesn't work......... Please check this out and help if you can:
https://honda-tech.com/zerothread?id=1269958
Old Jun 6, 2005 | 04:57 PM
Redline130's Avatar
Default Re: No cel and no vtec on a minime?!?!?! (WildPig)
I'm kinda leaning toward the oil jet, but I'm not too experienced with OBD2 motors. I'm putting together a mini-me with a HX (Y5) bottom, and there was no oil jet in the block, but it is a VTEC motor. I'm pretty sure all non-vtec bottoms have the oil jet in it. If you know for sure that there is no oil jet in the block, then I would check the solenoid to see if the filter is clogged up and not allowing sufficient oil pressure to activate VTEC.
Old Jun 6, 2005 | 07:20 PM
WildPig's Avatar
Default Re: No cel and no vtec on a minime?!?!?! (Redline130)
It's not the oil jet, y7 engines don't have the oil jets in the block like the older d series. Bump, still need help........
high_octane
Jun 16, 2009 01:55 PM
abolish415
Jun 13, 2005 10:48 AM
untitled
Aug 13, 2003 10:37 AM
KS-R
Jan 17, 2002 01:44 AM
