Newbie...... SOHC cam adjustments
Old Oct 8, 2002 | 07:23 PM
Turboboosted's Avatar
Default Newbie...... SOHC cam adjustments
I'm new to this honda thing so pls forgive me if i do crap..
i recently tried to adjust an AEM variable cam sprocket on a SOHC Vtec, I gave it 2 degrees advance with no noticeable difference.... i didnt want to push it more than that cuz i dunno what sorta piston to valve clearance these engines come with especially when the rougher cam kicks in...
what is a safe amount of adjustment for better acceleration???
.. the car ran 17.66 & after the 2 degrees advance it ran 17.43.... is this the most i could expect?????
thanx
Old Oct 9, 2002 | 04:27 PM
Default Re: Newbie...... SOHC cam adjustments (Turboboosted)
any help would be appreciated
Old Oct 9, 2002 | 04:52 PM
JaeOne3345's Avatar
u need to make sure u have an adjustable FPR..u dont want to advance to much without a bump in fuel. if u are trying to make more top end power then retard, more low end, the advance (as far as sohc goes)
Old Oct 11, 2002 | 03:16 AM
Mista Bone's Avatar
D Tranny Guru
alot depends on rpm range and gearing.
More info on your setup would help, but basically the cam gear was wasted money for you.
BTW did you change the ignition timing when you changed the cam timing?
Tuning, the lost art.
Old Oct 11, 2002 | 09:15 AM
tek_civic's Avatar
Default Re: Newbie...... SOHC cam adjustments (Mista Bone)
someone help this guy because i have the same problem, but i haven't yet bought a cam gear yet so i need to know if it's worth it.
jason190
Feb 17, 2005 07:22 AM
1point5CRX
Apr 13, 2004 07:29 PM
cbstd
Mar 28, 2003 10:14 AM
Sohc-Vtec
Aug 30, 2002 02:38 AM
azn_outlaw
Oct 27, 2001 02:19 PM
