i just swapped a jdm b18c1 into my 95 cx. it runs good while the engine is cold, but once the engine warms up, it will studder on acceleration in the low rpms and eventually stall out. the idle also randomly moves between 400 and 1000. i thought it could be the o2 sensor so i bought a new one but the car still stalls after about 15 minutes of driving. there is no cel and i have replaced plugs, wires, cap, rotor and fuel filter, as well as tested the resistitivity of the distributor coils and they were fine. i need help very badly. i don't know what else to do and i just want to drive my damn car.
vacuum leaks?..check your timing..what kind of plugs did you get?
i didnt bother checking timing cause its only a problem after the car is warmed up. same with the vacuum leaks, but i guess the hoses could expand or something under the heat, but its pretty consistent with the engine getting up to normal temp. i'll check tho.
and i'm runnin the gapless platnium ones. i think bosch makes them? i don't know its late.
ive heard bad things about the Bosch platinum 4's, i used to run them in my f22 accord, and you know what, i changed to NGK, and for some reason, it didnt run better but felt like it ran smoother, give it a try...
he forgot to mention that there is a misfire that can be heard quite often at idle. like not every 10 seconds. more every 1 or 2 seconds with a couple of random ones once in a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spartacus087 »</TD></TR><TR><TD CLASS="quote">he forgot to mention that there is a misfire that can be heard quite often at idle. like not every 10 seconds. more every 1 or 2 seconds with a couple of random ones once in a while</TD></TR></TABLE>
do you have a catalytic convertor on the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous »</TD></TR><TR><TD CLASS="quote">
nope.
...and thanks tyler.
</TD></TR></TABLE>nope.
help!!
it might be the knock sensor if ur motor has one or i think it might be something on honda that makes the car idle they offen go bad if the motor is a lil old should of stayed awake in auto's class i can get back 2 u with more info my friends crx use 2 idle crzy and it was an easy fix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chatch152 »</TD></TR><TR><TD CLASS="quote">i just swapped a jdm b18c1 into my 95 cx. it runs good while the engine is cold, but once the engine warms up, it will studder on acceleration in the low rpms and eventually stall out. the idle also randomly moves between 400 and 1000. i thought it could be the o2 sensor so i bought a new one but the car still stalls after about 15 minutes of driving. there is no cel and i have replaced plugs, wires, cap, rotor and fuel filter, as well as tested the resistitivity of the distributor coils and they were fine. i need help very badly. i don't know what else to do and i just want to drive my damn car. </TD></TR></TABLE>
What ECU does it have? What's your fuel presure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spartacus087 »</TD></TR><TR><TD CLASS="quote">stock fuel pressure and stock gsr ecu(p72??)</TD></TR></TABLE>
... yea what he said.
i got one of those in-line ignition spark checkers and after the car is warmed up, and i rev it, the bulb has inconsistent bright flashes. this is suppose to mean that some components of the ignition are weak. so my question is, could my distributor be bad, even though the coils' resistance check out to be ok?
bump...still not fixed. going to a mechanic soon. help
