obd0 b16
I had an occasional code 9 (cylinder position sensor) and the accompanying lack of power, stuttering, ect. So I ordered a new aftermarket distributor.
I came today. I installed it, and now the car runs rough as hell, and my wideband reads fully lean. Any ideas? I took the distributor key off the new dizzy and replaced it with the old key just in case maybe they had it wrong from the factory but that didn't help. firing order is correct, and when cyl 1 is at TDC, rotor is pointing to wire 1 in the dizzy cap.
Any ideas or help is appreciated. Thanks!
did u correct the timing after u installed it? and are the spark plug wires in the correct spots?
how would I know if the timing is correct? Besides a timing light? and if it was off, how would I adjust it? the timing belt side is correct. and yes the plug/wires are all correct. I put my other distributor back on and it runs fine....
u would need a timing light to check ur timing..here is how http://www.c-speedracing.com/howto/timing/timing.php
