new clutch engagment problems
i just put an exedy stock replacment clutch in my del sol vtec. i pull it out of the bay fine drive it about a mile. Well i'mm sitting at a light, it goes green so i start to take in first and it feel like it fell out of gear, i loook at the shifter and it is still in first gear position. so i try all the gears and none work, tried bleeding the clutch and it didn't help, although i didn't take off the slave cylnder when i changed the clutch so i wouldn't have to bleed it, but any ways now you put it in any geaer let off the clutch and nothing happens, no funny noises or anything, anyone have any ideas?? i think before i pull it out i'm goin to power bleed it but i doubt it will help, because it made no difference at allbefore.
The diaphram in my slave cylinder blew out one time....Had to replace it..I would try and bleed the lines 1st...then check the clyinder...
klystron59
Apr 25, 2010 04:56 PM
jxhxb
Oct 8, 2009 09:55 PM
SearchBeforeUPost!
Sep 2, 2003 08:42 AM
unidextrous
Jan 11, 2003 02:48 AM
