New BUILT Motor Almost Broke In And.......
Old Jun 10, 2002 | 08:53 PM
The Mole's Avatar
Default New BUILT Motor Almost Broke In And.......
It Feels Like A Damn Pig...
Very Sluggish At Bottom But ******* Throughs Me Back At Like
6000RPM's in fourth gear...
My Timing Is Retarted A Little...This Hurt At All?
Also Tonight When I Did The 4th Gear High Pull The Damn CEL Went *Bling Bling* In My Face... Knock Sensor Code 23 = Really Gay
Any One Have Any Ideas On That???
All Imput Is Apreciated..I Am Very Frustarted Right Now
And Off To Bed
Thanks,
Chris
Old Jun 10, 2002 | 10:30 PM
builthatch's Avatar
MiG-21 superfan
Default Re: New BUILT Motor Almost Broke In And....... (Silver EG)
way too rich on the bottom of the rev range, i'd guess, and yes, the retarded ig. timing will possibly hurt performance depending on the tuning needs of the engine...go to a dyno man; Especially with a built motor- the only way to get it rite.
Old Jun 11, 2002 | 12:30 AM
MikeSarr_GSR's Avatar
Default Re: New BUILT Motor Almost Broke In And....... (builthatch)
assuming you have a B motor:
are your cams indexed properly at TDC?
are you running special cam settings that are unproven?
how are your valves adjusted, if too tight... mak-a no powa
bone cold (rrom temperature) = .007in, .008ex <spec
timing should be tuned to 16-18BTDC+ depending on overlap period
hows your AFR?
any vaccum leaks?
loose ground wire> this can make the ignition system weak
loose throttle cable?
reset the computer the CEL richens the AFR and retards timing
new tune up stuff? air, fuel filters, cap/rotor, plugs, wires?
bald front tires?
slipping clutch>?
just some ideas!
hope you work it out man I understand the frustration!
Mike
Old Jun 11, 2002 | 04:33 AM
The Mole's Avatar
Default Re: New BUILT Motor Almost Broke In And....... (MikeSarr_GSR)
Hey Guys, I Appreciate The In Put But I Think It Must Be Timing...I Dint See It Rich, Oem Honda Computer And Injectors....maybe dist. has something toi do with it...??
Old Jun 11, 2002 | 06:55 AM
JaeOne3345's Avatar
u said almost broken in.i wouldnt be mashing almost broken in
Old Jun 11, 2002 | 09:35 PM
The Mole's Avatar
Default Re: New BUILT Motor Almost Broke In And....... (JaeOne3345)
948 miles opn it, no launches, just stepping on it in 4th & 5th, i have talked to some tuners around here, they said that was fine
hammergunner
Mar 25, 2009 07:27 PM
DesireeEJ6KiD
Oct 29, 2007 06:42 PM
sublimenerd
Sep 8, 2006 09:54 AM
nemesis0104
May 13, 2005 02:39 PM
