New? about spark plugs
Old Nov 13, 2002 | 08:07 PM
stupidfast's Avatar
Default New? about spark plugs
My friend just bought a 95ls.. So i did a tune up on it.. It has 130,000 miles. Well when i took the spark plugs out, they were really white and dry.. So i replaced them and checked about 10 miles later and they are already white. Whats causing this..? My quess is leaning out. But car is stock.. Wtf?? Any ideas?
Old Nov 13, 2002 | 09:26 PM
LB CRX's Avatar
Default Re: New? about spark plugs (stupidfast69)
the engine is running lean. check your timing/injectors
Old Nov 13, 2002 | 11:31 PM
kinesistech's Avatar
Default Re: New? about spark plugs (LB CRX)
Is it glossy white or just white. Glossy is bad, normal white isnt. If there is slight detonation it will look like very fine gliter on the insulator. Maybe compression is higher than normal because of carbon build up. Was that car well maintained, if not try cleaning it. What plugs did you use, maybe a colder one would help. Did you change the fuel filter?
Old Nov 14, 2002 | 06:18 AM
Desslok's Avatar
Default Re: New? about spark plugs (kinesistech)
The above posts are correct, but I also wanted to add that I have seen this when using Fuel injector cleaners or buying gas that has certain additives. Did you use injector cleaner? Maybe try getting gas somewhere else?
Old Nov 14, 2002 | 07:44 AM
stupidfast's Avatar
Default Re: New? about spark plugs (sp)
I did notice that the distributor was really advanced. So im going check that today and also replace the fuel filter and pump.. I have my stock gsr pump lying around so i will install that. Will post results..
Old Nov 14, 2002 | 09:16 AM
Soccerboy's Avatar
What does "really" advanced mean? More than 2 degrees, more than 4 degrees!?!?! This could lead to detonation but the ecu should retard the timing to compensate.
Old Nov 14, 2002 | 11:34 AM
stupidfast's Avatar
Default Re: New? about spark plugs (Soccerboy)
22 degrees when i checked it,, now at 16 degrees
Old Nov 14, 2002 | 12:02 PM
deleted's Avatar
There is no knock sensor on a LS motor. So if the motor was detonating, the ecu would not know.
Also, 22 degrees is a lot of advance!
Old Nov 14, 2002 | 01:00 PM
-KangaRod-'s Avatar
Default Re: New? about spark plugs (deleted)
egefcivicguy
Mar 14, 2013 04:09 AM
axionm1k
Jul 17, 2008 05:02 PM
elikas
Jan 18, 2007 07:40 PM
sporkcrx
Nov 12, 2002 05:56 PM
Turbo LS
Dec 20, 2001 12:02 PM
