Need tech help with head
Old Jul 20, 2003 | 10:42 AM
  #26
slofu's Avatar
Default Re: Need tech help with head (hatch4raceb16)
another thing: i think that in efforts to accomodate for more valve lift and rpm in the itr, that the itr outer intake springs are actually not as stiff as their b16a counterparts; the itr intake valves are shaved for weight reduction to offset this discrepency. so, taking the valvetrain over the stock b16a rev limit with lower spring pressure than stock, stock (heavier than itr) valves, and wilder (than b16a) cams could, as a combination, be the problem.
Old Jul 20, 2003 | 11:19 AM
  #27
hatch4raceb16's Avatar
Default Re: Need tech help with head (slofu)
ok, thats what i think too, i think this happened cuz i was taking running it too high, but still, how do i explain all the scoring on the rocker arms and what about the vtec cutting in and out? I think the vtec might just be the solenoid or bad wiring, but still, help, thanks.
Old Jul 20, 2003 | 02:53 PM
  #28
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">why would i need new rocker arms?</TD></TR></TABLE>
..because of...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">the scoring on the rocker arms</TD></TR></TABLE>
Old Jul 20, 2003 | 03:01 PM
  #29
Default Re: Need tech help with head (10K2HVN)
well they are still usable, its not like they are going to break. I was told by master mechanics at honda that they are definatly still usable, and that would not stop teh vtec from working either, so..............
Old Jul 21, 2003 | 11:21 AM
  #30
slofu's Avatar
i think that the scoring can happen when you float the valvtrain at high rpm. the springs can't quite keep the rocker pads pressed against the cams, so at some points, the lobes rotate and smack down against the rockers as the springs push them back up.
Old Jul 21, 2003 | 01:55 PM
  #31
dfoxengr's Avatar
Default Re: Need tech help with head (S8P-tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S8P-tuner &raquo;</TD></TR><TR><TD CLASS="quote">umm...just a question. i'm honestly not trying to be a dick, but i see people having problems with these frankenstein set ups, and i wonder where they get these ideas. why did you put the ITR cams and springs in? actually, i should ask why did you think they would work? like i said, i'm not trying to be a dick, i just don't know much about interchangeable drivetrain components. lowering springs are one thing...valve springs are entirely different. if there is proof that these cams and springs are supposed to work, then i don't know what the problem is. if there isn't proof, i think it should be quite obvious what the problem is.
i could be entirely wrong by saying this, considering i don't know what your intentions were, but if someone came into my shop and wanted to purchase ITR cams and springs for his/her b16, i would definitely question why. if it was because they are cheaper than aftermarket ones, i would question how that person knew these cams and springs would work, and if they don't, how much damage would they cause and would they end up costing more in the long run because they have to be replaced? if this is your story, next time, either don't do the mod or do it right. spend a little more and go with something that's proven to work right. at least if it breaks that way, the company that sold you the parts may be responsible. </TD></TR></TABLE>
u must be really ignorant becasue everyone knows b16 heads are the exact same as itr heads. i have to give you a hahaha. because there are so many poeple that do this.
shouldve used itr retainers.
Old Jul 22, 2003 | 07:39 PM
  #32
Default Re: Need tech help with head (Woofer)
bump
AranLamb
Sep 21, 2012 05:19 AM
perezryan21
Jun 22, 2012 07:58 AM
BIG_WILL
17
Sep 12, 2009 04:52 PM
white_n_slow
Jun 26, 2005 01:49 PM
bpowa
Jul 2, 2004 02:34 PM
