Need some technicians help! Stumped with cel 16
Old Jan 25, 2011 | 01:13 PM
k20superchargedtuboitbs's Avatar
Default Need some technicians help! Stumped with cel 16
need help on friends car.
Code 16, car has spark,fuel to rail, no injector spray.
ive checked the main relay, the dizzy, the ecu, ive tried known working ones from my car, no luck, will pay a tech to come over and fix the problem, so if you know anyone that might be able to fix it call me at 562 6466853
im assuming its some sort of wiring problem since all the parts related to that code have been checked and work, ive tested each injector as well and have used a diff set.
Old Jan 25, 2011 | 01:15 PM
95ProjectEJ1's Avatar
Default Re: WTB: mechanic / technician services $$$$. !!!!!!! cel 16
BUMP
Old Jan 25, 2011 | 01:17 PM
cancel's Avatar
most likely not getting signal to injectors
e//
try using a diff engine harnesS?
Old Jan 25, 2011 | 01:39 PM
screen_name's Avatar
yeah we've tried 3 diff harness
Old Jan 25, 2011 | 02:16 PM
cancel's Avatar
well youre getting fuel to the rail, just not injectors, so its either bad injectors or harness that or it could be the rail where the injectors not squirting other than that im out of ideas
you guys do a swap or anything? or is everything original
Old Jan 25, 2011 | 03:07 PM
Cortez_h's Avatar
Your not getting power from the relay to injectors. 90% sure there's a short between there.
Old Jan 25, 2011 | 03:24 PM
godluvstegs's Avatar
whats the car, motor, and location?
Old Jan 25, 2011 | 04:37 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Sent you text message on how to fix.
Old Jan 25, 2011 | 04:47 PM
BiG ChOr!Zo's Avatar
http://techauto.tripod.com/index.htm
Old Jan 26, 2011 | 11:02 AM
I've read that entire web site like 3 times, it has a bunch of great info, but everything checks out. We're stumped over here
Old Jan 28, 2011 | 05:14 PM
imptricer's Avatar
Default Re: Need some technicians help! Stumped with cel 16
have had this same problem ona freinds car ended up switching ecu's after everything you tried and something was f'd in the ecu but 9/10 its no signal
Old Jan 29, 2011 | 04:13 PM
99blackcivicSi's Avatar
whats the info on the car please?
Old Jan 29, 2011 | 09:26 PM
93 hatch, ls swap, its a dx model.
ive tried a working ecu, working main relay, working injectors, working dizzy
Old Jan 30, 2011 | 02:41 AM
do the injectors pulse?
have you checked grounds?
voltage to the injectors?
EFLS89
22
Feb 4, 2010 07:49 PM
sakasaku
Aug 20, 2009 01:27 PM
MUGEN_EG95
Sep 3, 2008 08:57 PM
T-sohctec
Aug 12, 2003 11:51 AM
