!!!!!!!NEED SOME HELP!!!!!!!p0230 code
Old Jun 7, 2010 | 05:19 PM
76hatch's Avatar
Icon3 !!!!!!!NEED SOME HELP!!!!!!!p0230 code
Im geting a 23 flash code on my 95 ls 4dr integra with 97 itr swap. One long flash with a quick one after then three relly fast ones is a 23 right. Not a 113. That would be one long flash a puse a nother long flash then three fast ones right. What would cause the p0230 code. What will fix it thanks.
Old Jun 7, 2010 | 06:10 PM
fcm's Avatar
fcm
Old Fart
Default Re: !!!!!!!NEED SOME HELP!!!!!!!p0230 code
95 Integra will be OBD1, a long blink and then a short blink would indicate 11, or one long and 4 short a 14, there is no code 11 and 14 is Idle Air Control Valve, [IAC]. 94
Old Jun 7, 2010 | 07:14 PM
76hatch's Avatar
so what would a po23o code flash like. fuel pump primary circuit malfunction. and there is a po113 code. Intake air temp circuit to high. What would that flash like.
Old Jun 7, 2010 | 07:19 PM
76hatch's Avatar
Icon3 Re: !!!!!!!NEED SOME HELP!!!!!!!p0230 code
so what would a po23o code flash like. fuel pump primary circuit malfunction. and there is a po113 code. Intake air temp circuit to high. What would that flash like. Its a total of 5 blinks one long one one right after then three really fast ones. A po2oo would flash one long then one right after right.
Old Jun 8, 2010 | 06:07 AM
fcm's Avatar
fcm
Old Fart
There is no code 23, [OBD1] or P0230, [OBD2] code 10, [OBD1] or P0113, [OBD2] is IAT "Intake Air Temperature" sensor circuit high input.
Again, your 95 is OBD1, a code 10 is also IAT sensor circuit low input, [P0112] and sensor circuit range/performance problem, [P0111]
Are you sure about the CEL flash back? 94
Old Jun 9, 2010 | 11:27 PM
76hatch's Avatar
Yes i know there is no code 23. I ment p0230, but it flashes as 23. Right since theres no p or 0 in the flash sequence.
Old Jun 11, 2010 | 05:21 AM
Dave-ROR's Avatar
Guys, he's running a 98 P73 ECU....
23 would be knock sensor if I remember correctly, but I'd have to look it up. fuel system is 40 something.
Old Jun 11, 2010 | 05:22 AM
Dave-ROR's Avatar
No, he's not.. based on his description in the ITR forum I suspect he's reading a 14 as you mentioned...
Old Jun 17, 2010 | 06:17 PM
76hatch's Avatar
Post Re: !!!!!!!NEED SOME HELP!!!!!!!p0230 code
Hey ror i didnt meen to cause problems. On the ITR forum. Its real cool your helping me out. I was a little angry when i posted my post, my bad. Yea ill have to do some trouble shooting. Thanks again, so by their standards. I wont be able to ever post in that forum. Because of my DC5 chasi? A lttle selfish if you ask me. And im not racist in any way. Im hispanic my self. Like i said i was a little pisst. When i posted last. Thanks again.
jdmazm
Apr 16, 2006 10:56 AM
civic4dr2000
Apr 2, 2006 04:41 PM
whatREDLINE
Jun 29, 2002 03:17 AM
whatREDLINE
Jun 28, 2002 07:17 PM
