Need some help with alternator wiring.
Old Feb 10, 2004 | 10:29 PM
Hoosier Daddy's Avatar
Default Need some help with alternator wiring.
Hey guys a friend of mine has an alternator from a 94-97 Integra. He wants to use it on his 2001 Integra. The clips, however, are different. Any idea how we can wire this up? We're trying to wire the 97 clip into his 2001 harness. Here are the wire colors on each clip:
94-97-
top left nothing
top right blue
bottom left black/yellow
bottom right white/blue
98-01-
top left black/yellow
top right white/green
bottom left white/blue
bottom right white/red
Top down picture of both(98-01 on left, 94-97 on right):
Any and all help would be very much appreciated.
Thanks
Old Feb 11, 2004 | 07:08 AM
todapower's Avatar
Default Re: Need some help with alternator wiring. (Hoosier Daddy)
Old Feb 11, 2004 | 10:25 AM
Anyone?
Old Feb 11, 2004 | 01:12 PM
todapower's Avatar
someone out there has to know.
Old Feb 12, 2004 | 04:44 AM
EE_Chris's Avatar
Default Re: Need some help with alternator wiring. (todapower)
To my knowledge, 3 and 4 wire alternators work differently, as in the ECU reads/controls them differently. On the 4 wire model, the additional wire lets the ECU know how hard the alternator is charging. No clue on what would happen if you just left this wire hang.
How the Honda Charging System works
Old Feb 13, 2004 | 10:53 AM
todapower's Avatar
Old Feb 13, 2004 | 02:44 PM
PHiZ's Avatar
http://www.hondaswap.com/forum...29360
That should work well enough, you can leave teh ALT-C wire disconnected. It's kinda like a clutch switch, and the ecu is allowed to dynamically enable/disable the alternator.
-PHiZ
Old Mar 1, 2004 | 07:55 AM
rice4life's Avatar
Default Re: Need some help with alternator wiring. (PHiZ)
i'm have the same proble. i'm using a 97 ls harness on a 98 jdm R. the jdm R alternator has 4 pins and the 97 ls harness has 3 pins. i'm using a chiped p28. does the p28 use 4 or 3 wire alternator?
TylerC161
Mar 9, 2007 07:19 PM
mckeehan
Honda Civic (2001 - 2005)
Nov 19, 2006 09:34 PM
hatchback_al
Oct 26, 2003 08:57 AM
