need to sell this engine
Old Oct 5, 2005 | 06:53 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default need to sell this engine
i am not trying to sell the engine in this forum
i just want to know how much you think i should sell it for.
its a JDM b16a obd0 with less than 40,000 miles, that comes with gsr cams, the engine is completely stock other than that. the engine pulled real good when it was installed in my crx. i am not sure if i am going to sell it with the stock non-lsd tranny or with a LS tranny, engine does come with an exedy stage 1 clutch and the stock flywheel.
the engine doesnt have a vtec solenoid or distributor, and cam seal is leaking, doesnt come with the distributor b/c it was switch from obd0 to obd1
so how much do you think that i should sell just the engine for and how much more with the LS tranny?
thanks in advance
Old Oct 5, 2005 | 10:00 PM
Kendall's Avatar
I'd say no more than a thousand bucks, and no more than about eight hundred with the LS tranny.
Old Oct 7, 2005 | 09:02 AM
fastasscrx's Avatar
Default Re: need to sell this engine (turbob16EF)
I'll give ya 350 for just the motor(no dizzy,no solenoid, cam seal leaking, and not sure if it runs!)
sykotic
Aug 21, 2005 10:54 PM
allmotorEG-SI
May 30, 2004 11:05 AM
allmotorEG-SI
May 10, 2004 05:25 PM
integraautox
Sep 11, 2003 03:06 PM
93delsol
Aug 4, 2002 08:14 AM
