Between which pins on the sensors? When the car is off, on, etc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">Between which pins on the sensors? When the car is off, on, etc?</TD></TR></TABLE>
There are only two pins, so between them. You can't check resistances with voltage applied, so the car has to be off.
thanks alot chris.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">
There are only two pins, so between them. You can't check resistances with voltage applied, so the car has to be off.</TD></TR></TABLE>
doh! Failed to realize they were both 2 pin sensors, I thought they were 3 for some reason
Awesome diagram though!
*booked
