need pointers on B18C1 build-up
Old May 6, 2002 | 09:13 PM
LSturboHB's Avatar
Default need pointers on B18C1 build-up
i have a b18c1 and i want to start to build it. i am looking to get the most HP/tq out of it without doing any serious machine work to it. and i am looking for about 180-200 WHP. what do i need for this. oh yea i want to keep it NA.
thanks for any info.
Old May 6, 2002 | 10:40 PM
MikeSarr_GSR's Avatar
Default Re: need pointers on B18C1 build-up (LSturboHB)
LEARN!!
too much cam wont do the job, so right off the bat dont look into huge duration and lift cams. if you get your headwork square, you can use type r cams with
a thinner gasket and flat valves to make more compression, cam, ecu, intake, exhaust and VAFC microtuning can help you get there. there is a cat on this board with a 1994 GSR with 202/143 at the wheels. this is a major accomplishment considering he has all ITR stock parts on the motor, cams, header, muffler, intake manifold and STOCK bottom end all motor. he didnt list his compression ratio, I would guess with a thinner head gasket, flat valves and a small .0020" mill he could be around 11-11.5:1 and running pump 92-93 octane happily. there are no
short cuts with building a motor. do your homework!!! this guy obviously did...
http://www.geocities.com/gzr4dr/homepage.html
here is what I suggest:
research/do head & valvetrain work,
up compression with head tricks > 1500-2500
CTR honda cams > 500
manifold port and polishing > free horsepower
get a drop in filter, use stock airbox and run fresh air to it > almost free hp
tune cams, timing, vafc and fuel pressure > 800
tune intake, header and exhaust > 1500+
tune ecu, retune vafc and cams > find a good/reasonable dyno guy and learn
people have achieved this mark then you could
research what you can do with the bottom end... 1500-3500
retune...
I would say that 220/155 all motor on a GSR would be very possible.
for about 5K you could make this mark... the trial and error may
kill you in the process!
http://www.importreview.com
http://www.theoldone.com
http://www.hondata.com
http://www.hytechexhaust.com
oh yea, the car needs to stop too.. and corner.. .and grip...
you get the point I am sure.
Old May 7, 2002 | 12:35 AM
Kamin's Avatar
Default Re: need pointers on B18C1 build-up (MikeSarr_GSR)
damn...that pretty well sums alot up
only thing i would change is get a cold air intake, not a drop in filter
and TUNING!
tuning is everything. you might want to look at hondata for an ecu (stages 1 and 2) it will help significantly.
good luck
Old May 7, 2002 | 06:27 AM
LSturboHB's Avatar
i should of asked my question differently.
i want to use alot of JDM ITR parts, pistons, intake manifold, CTR cams, ITR header,Spoon flat filter stock AB. PP the head. Mugen 1 pc head gasket which i have already. what are some numbers i'll get with these mods? about. if i am not close to my mark of 200WHP what else would be an way to get there. besides boost my HB is boosted now, i want to go NA for a change. What about B20/Vtec would this be a better route ? i need reliability.
thanks
JDM_teh_WIN!!
10
Sep 12, 2008 06:17 AM
cherryhatch00
17
Jan 6, 2007 08:09 AM
louie3252
Jan 7, 2006 06:30 PM
thegrayghost
Dec 12, 2005 05:22 PM
thegrayghost
Nov 11, 2005 10:54 PM
