need modification help
Old Aug 5, 2006 | 06:50 PM
ef8pro's Avatar
Default need modification help
I've been building a crx for track purposes, and have been considering to get a dry sump pump, so I can lower the engine as far in the chasis as possible, but I was wondering how I would go about actually lowering the motor. Do I need to relocate the motor mount braces or what. Someone here fas got to know, so help me out guys. Thanks
Old Aug 5, 2006 | 10:08 PM
SuzukaBlueAP2's Avatar
Default Re: need modification help (ef8pro)
I don't think just lowering the engine is going to yield you any great advantage.
If you were lowering it AND moving it closer to the center of the vehicle for a more near 50/50 weight dist., then I would see where it might help.
At any rate, let's just go ahead and say that you did lower it. Remember that this now changes the location of your shift linkage and axles. You have to compensate those as well.
Old Aug 6, 2006 | 07:32 AM
ef8pro's Avatar
lowering the motor would give a lower center of gravity wouldn't it, so that should reduce a lot of the body roll,right. That's just my theory though. I'm putting the pump in either way.
SirDreadsALot
Jan 6, 2011 09:09 PM
Royal_C!ty
Northwest (Sales)
Mar 3, 2006 02:02 PM
LuDeRsH415
Jun 1, 2005 06:32 PM
dohcdelsol
Aug 10, 2004 07:46 PM
porfavor
May 20, 2004 09:36 PM
