need knowledge on OBD11-1
Are there any downsides to this conversion? It it as functional as an original OBD1 motor? can i eliminate 2nd 02 sensor?
thanks........
[Modified by 98DC2, 10:06 AM 9/12/2002]
[Modified by 98DC2, 8:44 PM 9/12/2002]
What are you saying, do you wanna swap your whole interior wiring harness?? If your car is OBD2 and you want to make it not run those few sensors that are customary of OBD2 then just run a conversion harness.
thanks........
thanks........
Another thing you can look into is running a JDM OBD2 ecu.....those also do not look for a 2nd 02 or CKP sensor (sensor on oil pump), and VTEC pressure switch (green plug on vtec solenoid). Its basically thinks like an OBD1 ecu but is OBD2 hardware.
JerseySiPOS
Nov 27, 2013 12:26 PM
JBirch_97Prelude
May 23, 2006 03:11 PM
