Need to know which one is original IACV
Old Apr 5, 2017 | 10:58 AM
CCrown's Avatar
Default Need to know which one is original IACV
Good Afternoon,
I have two IACV for this Honda that i am still trying to get to run correctly. I am trying to get an idea which one would be the correct valve for this B16A2 engine. Only difference is the orifice size. Both shows Ohms at 11.2 and 11.4, Any idea.
Thanks
Also does the ohms sound correct?
Old Apr 5, 2017 | 10:17 PM
holmesnmanny's Avatar
Default Re: Need to know which one is original IACV
The bottom one looks like a Honda one. Honda's don't have that obstruction inside like the left port of the top one does.
Old Apr 6, 2017 | 08:06 AM
NVturbo's Avatar
O.G. triple O.G.
Use the top one. A friend had issues on his '98 Civic HX and I found one for him from the local salvage yard. Swapped it out, cleared the CEL and problem gone. The wire plug connections as well as the water hose are exactly the same.
Shojin
Mar 8, 2023 05:35 AM
David Cottle
Jan 18, 2014 08:41 PM
Radcliff89
Jan 12, 2011 11:36 AM
AViciousTHRUST
May 5, 2006 09:36 PM
