Need help w/ e-manage support tool
Old Jun 29, 2005 | 06:15 PM
abmerop18's Avatar
Default Need help w/ e-manage support tool
I purchased the e-manage support tool and I am aware that I have to use this exact cable or it will not work to connect to my laptop. The problem is that I do not have a 9-pin port on my new dell laptop. I purchased a cable to convert the 9-pin greddy cable to a usb cable and connect the greddy to my usb port instead. I cannot communicate with the emanage now though. It is saying that it is offline. What do I need to do to get it to work with it now on the USB port instead of the com port? Is this possible to run the emanage off the USB port? Thanks for th help.
Old Jun 29, 2005 | 06:54 PM
abmerop18's Avatar
Default Re: Need help w/ e-manage support tool (abmerop18)
anyone?
Old Jun 29, 2005 | 07:04 PM
90crvtec's Avatar
Your Serial to USB adapter will take a new com port number in Windows. Make sure that your software is looking for the correct com port. If the adapter is now on COM3 make sure your support tool is also pointing to COM3. A screenshot of your device manager might help.
Old Jun 30, 2005 | 03:42 AM
abmerop18's Avatar
Default Re: Need help w/ e-manage support tool (90crvtec)
how do i set this?
Old Jun 30, 2005 | 08:05 AM
abmerop18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">how do i set this?</TD></TR></TABLE>
Old Jun 30, 2005 | 09:12 AM
BigDaddyRich's Avatar
Un fortunately I do not know of anyone that has successfully used a serial to USB converter on the E-manage cable, as its chipped..
I am currently using the E-manage on my IS300 and I use it via the serial port only.
You can try the com port trick by launching the Emanage software and going to the options menu and selecting COM Ports sub menus and selecting something other than COM1 .... perhaps COM2 or COM3.
Good Luck.
Old Jun 30, 2005 | 12:59 PM
abmerop18's Avatar
Default Re: Need help w/ e-manage support tool (BigDaddyRich)
yeah, i tried all the other posts on the e-manage support tool and none of them worked. it was offline for all of them
Old Jun 30, 2005 | 07:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i tried all the other posts on the e-manage support tool and none of them worked. it was offline for all of them</TD></TR></TABLE>
Notto sound foolish, but have you even attempted to call GReddy USA to answer your serial2USB converter cable dilemma? maybe they have a way for you to get it to work of you dont have a serial port on your laptop?
Old Jul 1, 2005 | 04:24 AM
abmerop18's Avatar
ill give that a try. thanks
SOHC_2_DOHC
Dec 12, 2007 11:02 PM
N.A.N00B
Oct 28, 2004 04:30 PM
bh2285
Aug 30, 2004 11:25 PM
oojoe24oo
Mar 25, 2004 07:31 PM
hb_racer
Mar 25, 2004 03:01 PM
