need help on transmission problem
Old Dec 25, 2004 | 02:40 PM
dayaftertomorrow's Avatar
Default need help on transmission problem
I have a civic swaped with a 2000 b18c with gsr transmission. There is a problem only with the 1st gear and the rest of the gear are fine. 3 out of 10 time I could not **** to 1st gear, sometime I either like hit a wall or half way stop on the gear. Please give some advice on what causes it. Thanks
Old Dec 26, 2004 | 06:31 AM
Rod.'s Avatar
Default Re: need help on transmission problem (dayaftertomorrow)
shift fork could be a little bent
Old Dec 26, 2004 | 08:01 AM
primeredbeast's Avatar
make sure you stopped all the way when downshifting
Old Dec 26, 2004 | 10:56 AM
Default Re: need help on transmission problem (redturbocivic)
someone told me that it is the pressure plate. I am so confused. How do I tell it is the shift fork. Thanks
Old Dec 27, 2004 | 06:19 AM
tgreaves's Avatar
As far as I know the only way to tell if its a shift fork is to open it up and take a look.. Bent/broken shift forks do some strange things..
Old Jan 2, 2005 | 08:32 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i have never seen a bent shift fork out of about 30 broken trannies. actually i did and all three were bent cuz the tranny was dropped several feet off a forklift . on your changer/selector mechanism which moves the shift forks up and down, they are just thin metal tabs...you have three for the three forks (1/2, 3/4, and 5/R). 1/2 and 5/R (ones on the outsides) are the easiest and only ones that can actually bend. your 1/2 tab is bent out of whack. it would be obvious if you opened it up and looked at it.
ATpossible
12
Mar 3, 2007 05:52 PM
petrv
Mar 28, 2006 07:10 AM
JDM4DRACCORD
May 23, 2005 09:03 AM
mikestypeR
Mar 2, 2004 04:44 PM
Juantay19
Apr 2, 2002 10:43 AM
