Need help with tranny/clutch problem...
Old Sep 24, 2003 | 05:56 AM
B18PoweredCivic's Avatar
Default Need help with tranny/clutch problem...
Everytime i push down the clutch pedal to enage the shifter into first gear it wont go in..I have to push it down a few times and mess with it to get it into gear...I tried bleeding the slave cylinder and that didnt help...COuld it be the slave cylinder thats bad or could the throw-out bearing be bad..Any help would be appreciated...Thanks
Old Sep 24, 2003 | 06:03 AM
mike1114's Avatar
Default Re: Need help with tranny/clutch problem... (B18PoweredCivic)
master cylinder is bad. replace master and slave at same time. autozone etc...has them if you don't want to buy from honda or you can't find some used.
U can check for leaks on the carpet inside on drivers side master cyl comes through firewall, but it is possible for a seal to leak inside and you will not see a wet spot
Old Sep 24, 2003 | 10:58 AM
TimoneX's Avatar
New User
Default Re: Need help with tranny/clutch problem... (mike1114)
No offense, but what makes you so sure it's the master cylinder Mike? Shouldn't he have a soft clutch pedal if it's a master or slave cylinder problem? Does your clutch pedal feel abnormal B18? Any unusual sounds or vibrations while shifting?
Mugen112
Jul 16, 2009 07:14 PM
phookie
Jan 27, 2009 08:25 PM
tato1983
Dec 11, 2007 05:52 PM
majinx4
Jun 14, 2006 05:46 AM
tbonez
Jun 12, 2005 05:27 PM
